Explaining C: How Space Changes with Speed
  • Thread starter Reflector
  • Tags
    Explain
In summary: LT to it and conclude that it contracts in the direction of motion. So SR is not about EM interactions, but it does arise from EM thought.In summary, the conversation discusses the invariance of the speed of light and its relationship to electromagnetism and spacetime. Some argue that electromagnetism is the reason for the invariance of the speed of light, while others believe it is the other way around. The theory of relativity, particularly special relativity, is also mentioned as a way to understand these concepts. The conversation also touches on the role of electrodynamics at the atomic level and how it relates to macroscopic relativistic effects.
  • #106
zoobyshoe said:
Halliday and Resnik say this equation is for transforming from the primed into the unprimed frame. We are definitely going the other way.
Here are the complete set of Lorentz Transformations:
[tex]\Delta t' = \gamma(\Delta t - v\Delta x/c^2)[/tex]
[tex]\Delta x' = \gamma(\Delta x - v\Delta t)[/tex]
[tex]\Delta t = \gamma(\Delta t' + v\Delta x'/c^2)[/tex]
[tex]\Delta x = \gamma(\Delta x' + v\Delta t')[/tex]
Sure, the first two allow you to go from unprimed measurements to primed measurements. And vice versa, for the last two, which are called the inverse LTs. But remember, these are just equations like any other--you can use them any way you want, as long as you plug in the right values.
The main objective is to find the length that someone will measure the marks left by the rod in the rail frame to be. There should be two burn marks left by the flares which are .866025 apart, which prove the rod has "really" contracted while at speed .5c.
Right. So we need to find [itex]\Delta x[/itex]. What are we given? We know that its a meterstick, so [itex]\Delta x'[/itex] = 1m. We also know that the flares go off simultaneously in the unprimed frame, so [itex]\Delta t[/itex] = 0. Now which LT relates those three values? Try the second one:
Plugging in what we know, it becomes:
[tex]\Delta x' = \gamma\Delta x[/tex]
or:
[tex]\Delta x = \Delta x'/\gamma[/tex]
Which tells you that the measured length is the expected 0.866m.
I can promise you that, yes, but it won't help you: I have an extensive vocabulary of alternatives. :-)
Lucky for you I'm a mentor here. In "real life" I'd rip you to shreds without mercy! (Just kidding. :-p)
I love Seinfeld, but that line doesn't ring a bell at all. I just figured you were witnessing your Faith in The Church Of Relativity. Praise Einstein!
The original line is: "They're real... and they're spectacular!".
