Explaining internal energy (A level physics)
In summary, the conversation discusses the concept of internal energy in different states of matter, including ideal gas and solid. The potential energy term and its relation to changes in energy during phase changes are also mentioned. The speaker distinguishes between kinetic energy, potential energy, and internal energy, and gives examples of each. The relationship between internal energy and the molecular structure of substances is also discussed.
VEReade
I’m having a mental block re. teaching internal energy. Here’s the issue:
For ideal gas, internal energy is entirely kinetic energy. I explain to students this is because there are no interatomic forces of attraction.
Now, a solid...internal energy is sum of kinetic energy and potential energy. The interatomic forces cause potential energy term.
Here’s the issue, work has to be done on particles going from solid to gaseous state. So particles in solid state have less potential energy than when at infinity. Looks like potential energy term is negative. Looks like internal energy could go negative - that sounds bad..!?
Guidance appreciated!?
Science news on Phys.org
The idea of the internal energy being negative is ok. If you look at simple atomic theory, and the Bohr model of the hydrogen atom, all of the computed energy levels are negative. The important parameter here is simply the change in energy that occurs in going from one state to another. What is used as the zero reference energy level is somewhat arbitrary, but in these cases it is the separated particles in a motionless state.
Likes VEReade
Thanks, that makes sense.
UK A - level physics students used to have to know the potential energy against separation graph. I think it’s been removed from specifications these days - the ones I know anyway. I think this is influencing my thinking as regards teaching internal energy!
As you say, it’s changes in internal energy during , say, phase changes which lead to an understanding of latent heat etc. From a teaching point of view, it is probably best way to approach it...
Likes Charles Link
For academic reasons I find separating energy into three distinctive issues; that is, Kinetic Energy, Potential Energy (or, Positional Energy) and Internal Energy. I must confess that I'm a chemistry professor, not a physics prof, so my distinctions between these energy 'types' is chemistry oriented. Here's my definitions and examples ...
Kinetic Energy is the mechanical energy of motion, Potential energy is mechanical stored energy and Internal energy is the energy content of a system due to its state of existence and chemical structure. That is, state of existence meaning solid, liquid or gas and chemical structure meaning the substances molecular geometry. This is generally a macro molecular interpretation as opposed to a kinetic micro molecular particle level interpretations, but does give a more physical illustration of changes in internal energy.
Consider Water (good old H2O)... It can exist as solid (ice), liquid (water) or gas (steam) but its chemical structure is always bent angular with two covalent bond and two non-bonded pair of electrons around the central element oxygen. To change the structure would be to change the molecule and the internal energy of water that supports this structural configuration.
243409
https://www.google.com/search?rlz=1...TiAhXlmq0KHUmSCFAQ7Al6BAgJEA0&biw=1536&bih=722
Typically, for chemical reactions, changes in internal energy is calculated from the 1st Law equation ΔURxn = Heat of Reaction (q) + Work of Rxn (w) = ΔHRxn + Pressure(P)⋅ΔMolar Volume of gasses (V), or simply ΔU = ΔH + P⋅ΔVm.
Heat of Reaction (or, Enthalpy of Rxn) can be calculated using the Hess's Law Equation ΔHRxn = Σn⋅ΔHfo(Products) - Σn⋅ΔHfo(Reactants) which shows a clear differential numerically in energy content.
Work of Reaction depends upon changes in molar volumes of gasses (ΣVm(products) - ΣVm(reactants). If ΔVm > 0 => work is exothermic expansion and is subtracted from the Heat of Reaction; if ΔVm < 0 => work is endothermic compression and is added to the Heat of Reaction and if If ΔVm = 0 => work is isothermic (w = 0) and ΔURxn = ΔHRxn.
Example (Open System, ΔVm ≠ 0)
3H2(g) + N2(g) => 2NH3(g); ΔHRxn = -91.8 Kj
The reaction shows 4Vm(reactants) → 2Vm(products) => decrease in 2Vm net change in molar volume and is a compression reaction. Therefore, work is endothermic (w > 0 ) ~ +5.0 Kj. Therefore, the change in Internal Energy (ΔU) = ΔH + P⋅ΔVm = -91.8Kj + (+5.0Kj) = -86.8Kj (net).
Considering structural differences between reactants and products, one can see a clear difference in structure between H - H and O=O giving a pyramidal structure for gaseous ammonia. That is, the internal energy of ammonia is 91.8Kj less than the internal energy of H2(g) and O2(g).
243410
https://www.google.com/search?rlz=1....0.60.534.10...1...1..gws-wiz-img.xzAEwcWMe5g
Clearly different structure than H - H and O = O and thus different internal energy holding the structure in a pyramidal geometry.
Likes VEReade and sysprog
Related to Explaining internal energy (A level physics)
What is internal energy?
Internal energy is the sum of all the microscopic kinetic and potential energies of the molecules that make up a system. It includes both the kinetic energy of molecules in motion and the potential energy stored in the bonds between molecules.
What factors affect the internal energy of a system?
The internal energy of a system is affected by the temperature, pressure, and number of particles present in the system. It also depends on the types of particles and their interactions with each other.
How is internal energy related to work and heat?
Internal energy can change due to work done on or by the system, or due to heat transfer into or out of the system. An increase in internal energy due to work is called work done on the system, while an increase due to heat transfer is called heat supplied to the system.
What is the first law of thermodynamics?
The first law of thermodynamics is the law of conservation of energy applied to thermodynamic systems. It states that the change in internal energy of a system is equal to the net heat transfer into the system minus the net work done by the system.
How is internal energy measured and expressed?
Internal energy is measured in joules (J) or kilojoules (kJ) and can be expressed in terms of the temperature, pressure, and volume of the system using the ideal gas law. It can also be measured using calorimetry, which involves measuring the heat transferred during a process to calculate the change in internal energy.
  • Materials and Chemical Engineering
  • STEM Educators and Teaching
