Explaining Missing Decimal Numbers 3, 6 & 9 in Calculations
  • Thread starter Thread starter Hippasos
Hippasos
1/56=0,017857142857142857142857...142857
1/7=0,142857142857142857142857...142857
142857
142857/7=
20408,142857142857142857...142857
20408/7=
2915,42857142857142857...142857
2915/7=
416,42857142857142857142857...142857
416/7=
59,42857142857142857142857...142857
59/7=
8,42857142857142857142857...142857
8/7
1,142857142857142857142857...142857
Missing decimal numbers 3 - why are these"missing"? Not needed even during calculations - at all?
Can You please explain?
what's to explain? it's just the result of particular calculations.
Hey, try 1/3 = .333333 you don't need 1,2,4,5,6,7,8, or 9 Explain that !
Yes of course my stupid mistake. I was *runk and it was late. Still interesting ...142857.. cycles there.
Hey! don't dismiss your observation so quickly. It is very interesting and if you look at the long division process you can see just why there are no 3 or multiples of, in the decimal expansion.
First of all observe that there are at most 6 digits possible. There is a limited set of possible remainders in the long division process{1,2,3,4,5,6}. A zero would terminate the process, 7 and greater means that you have not made a correct choice of a multiplier. This implies that there can be at most 6 digits in the expansion. 7 is unique in that it is the only integer with the max possible number of unique digits in the decimal expansion.
Now let's go through the long division process and see if we can see why 3 does not appear.
The first step:
10/7 = 1 r 3 : so 1 is the first digit the remainder sets up the second step, r*10
30/7 = 4 t 2 : so 4 is the 2nd digit.
20/7= 2 r 6 : so 2 is the 3rd digit.
now we can see why 3 does not appear, each of the steps involves a multiple of 10 divided by 7. But the only way to get a 3 would be if you could have a non zero as the last digit, this cannot happen. Since 7*3=21 and 7*4=28.
I also find this an interesting little tidbit. Hope I helped throw some light on it for you.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
