Explaining Time Homogeneous Lagrangian and Hamiltonian Conservation
If the Lagrangian is time-homogeneous, the Hamiltonian is indeed a conserved quantity, as indicated by the condition ∂L/∂t = 0. This means that in systems where the Lagrangian does not explicitly depend on time, the Hamiltonian represents a constant of motion. A common example is the simple harmonic oscillator, where the Hamiltonian corresponds to the total energy of the system, combining kinetic and potential energy. The discussion also touches on deriving Hamilton's equations to further validate this relationship. Understanding these principles is crucial for analyzing dynamic systems in classical mechanics.
eman2009
if the lagrangian is time homogenous ,the hamiltonian is a constant of the motion .
Is this statement correct ?
if \frac{\partial L}{\partial t}=0 then the hamiltonian is a conserved quantity. So yes. If the lagrangian doesn't explicitly depend on time, H is conserved.
can you give me example ?
well, the typical situation (where your coordinates are somewhat normal (ie, can be related somehow to the cartesian coordinate system in a time independent fashion) then the hamiltonian is the energy of the system.
ie, simple harmonic oscillator:
L=T-U= 1/2 m x'^2 - 1/2 k x^2
where m is the mass, k is the spring constant, the first term is the kinetic energy (1/2 m v^2) and the second term is the potential (1/2 k x^2)
in this case H=T+U = Kinetic Energy + Potential Energy = Total Energy = Constant
Mandatory exercise: Derive Hamilton's equations and prove the result.
how we can explain the differential of lagrangian is a perfect ?L dt
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
