Explanation of a simple exponent rule in a derivative problem needed
AwesomeSN
Explanation of a "simple" exponent rule in a derivative problem needed
After differentiation, I get this : 9(t-2/2t+1)8 * 5/(2t+1)2
Now this simplifies into 45(t-2)/(2t+1)10
Now, I am wondering what the property is that combines the exponent from the top with the bottom to get an power of 10 in the simplified form.
*Note. the t-2/2t+1 is t-2 over 2t+1, the 5/(2t+1)2 is 5 over (2t+1)2, and the 45(t-2)/(2t+1)10 is 45(t-2) over (2t+1)10.
From the rules of exponents:
a^n a^m = a^{n+m}
if you start with 9 (\frac{t-2}{2t+1})^8 * \frac{5}{(2t+1)^2}
then you can write 9 \frac{(t-2)^8}{(2t+1)^8}* \frac{5}{(2t+1)^2}
and then you add the exponents when multiplying like bases, thus getting 45 \frac{(t-2)^8}{(2t+1)^{10}}
Note that (2t+1)^8(2t+1)^2=(2t+1)^{10}
edit:
boo, pibond beat me cause I'm slow at latex! :P
Thank you. I was aware of the rule for exponents, but applying the power of 8 to both the numerator and denominator escaped me, now it all makes sense!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
