Explanation of the wording - Electromagnetism Question
In summary: pere's law gives the magnetic field at the centre of a long solenoid (ie. all lines of force go through the centre) as:
Brewer
212
Could someone explain the wording (and possibly see if I'm going the right way about it) of this question to me.
What is the current required in the windings of a long solenoid that has 1000 turns uniformly distributed over a length of 0.400m, o produce at the centre of the solenoid a magnetic field of magnitude 0.1mT.
The wording I'm concerned about is about the turns. Is the wire 40cm long with 1000 turns, or is each turn 40cm long?
Anyway to the working:
I thought initially to use F=nBIl, but as no force is given I can't use it can I? Is it something to with Biot-Savart's law?
I want to use the form, B= NI(mew0)/2a, but I can't think how to find a, the distance to the center of the circular loop. Any hints?
I would say that the total length of the wire is 40cm long. The fact that it says the turns are uninformally distrobuted over 40cm kinda gives it away :smile:
I'd go with that. I think I have it sussed from here. (Actually I reread the question and it made sense!)
D'oh!
It means the solenoid length is .4 m. You don't care about the length of the wire.
The magnetic field at the centre of a long solenoid (ie. all lines of force go through the centre) is given by Ampere's law for a rectangular path through the centre and enclosing all the windings: [itex]
\oint B\cdot ds = \mu I[/itex]. Since B is constant throughout the solenoid length and the rest of the path integral sums to 0, the left side works out to BL. Work out the right side (keeping in mind that I is the current enclosed by the path) and that will enable you to find the expression for I in terms of B, L and N.
AM
FAQ: Explanation of the wording - Electromagnetism Question
What is electromagnetism?
Electromagnetism is a branch of physics that deals with the interactions between electricity and magnetism. It explains how electric charges create electric fields and how moving charges create magnetic fields.
How does electromagnetism work?
Electromagnetism works by the interaction between electric charges and magnetic fields. When an electric charge moves, it creates a magnetic field around it. Similarly, when a moving magnetic field passes through a conductor, it induces an electric current. This is known as electromagnetic induction.
What are the key principles of electromagnetism?
The key principles of electromagnetism include the law of electric charges, which states that like charges repel each other and opposite charges attract, and the law of magnetic poles, which states that like magnetic poles repel each other and opposite poles attract. Other key principles include Faraday's law of induction and Ampere's law.
How is electromagnetism used in everyday life?
Electromagnetism has many practical applications in everyday life. Some examples include electric motors, which use the interaction between electric and magnetic fields to produce motion, and generators, which use electromagnetic induction to convert mechanical energy into electrical energy. Electromagnetism is also used in electronic devices such as televisions, radios, and computers.
What are some real-life examples of electromagnetism?
Some real-life examples of electromagnetism include the Earth's magnetic field, which is created by the movement of molten iron in the Earth's core, and the Northern Lights, which are caused by the interaction between charged particles from the sun and the Earth's magnetic field. Other examples include MRI scans, which use strong magnetic fields and radio waves to create images of the body, and electric power transmission, which uses electromagnetic induction to transfer electricity over long distances.
