- #71
Mehdi_
- 65
What is the website of your quaternion publications
garrett said:So, the correct expression for the inverse Killing vector field should be
[tex]
\xi^-_i{}^B = - < \left( (T_i - x^i) \frac{\sin(r)}{r} + x^i x^j T_j ( \frac{\cos(r)}{r^2} - \frac{\sin(r)}{r^3}) \right) \left( \cos(r) - x^k T_k \frac{\sin(r)}{r} \right) T_B >
[/tex]
[tex]
= \delta_{iB} \frac{\sin(r)\cos(r)}{r} + x^i x^B ( \frac{1}{r^2} - \frac{\sin(r)\cos(r)}{r^3} ) + \epsilon_{ikB} x^k \frac{\sin^2(r)}{r^2}
[/tex]
Mehdi_ said:the Killing vector fields corresponding to the right action of the su(2) Lie generators will take me a while... I have no idea about how to do... but you say that Joe almost got them ?
post me here Joe answer ... I will try to study it and after doing some research in internet maybe I will be able to understand how a Killing vector fields could be defined from a group (SU(2))... maybe we have to define the agebra... and the adjoint representation... Lie bracket... all my post now will be related to this question... I hope that it will not take me too much time...;)
garrett said:[tex]
\vec{\xi_A} \underrightarrow{d} g = \xi_A{}^i \partial_i g
[/tex]
garrett said:Hey, would you like to offer up the correct answer to the last question about the commutation relations between the two sets of Killing vector fields?
garrett said:Ah, yes, mathematicians often write a vector operating on a function as [itex]\vec{v}f = v^i \partial_i f[/itex]. I do not write it that way. Instead, I would write the same thing as
[tex]
\vec{v} \underrightarrow{\partial} f = v^i \partial_i f
[/tex]
I like to have conservation of arrows in my notation. :)
Taoy said:Oooh, so vectors act on scalars the same as vectors act on one-forms?
So how would you conserve the arrows in:
[tex]
({\cal L}_{\vec{X}} \vec{Y}) f = (\vec{X} \vec{Y} f -\vec{X} \vec{Y} f)
[/tex]
garrett said:Yes, after all, a scalar is just a 0-form.Taoy said:Oooh, so vectors act on scalars the same as vectors act on one-forms?
garrett said:I'll stop here and give the remaining symmetry relationship as a quick "homework" problem:
What's the Lie derivative of one of the "left invariant" vector fields with respect to one of the "right invariant" vector fields?
[tex]
L_{\vec{\xi_A}} \vec{\xi'_B} = ?
[/tex]
garrett said:Don't freak out Joe, everything works just fine...
Zero is the right answer, for the reason you said. But can you go clean up the arrows above and put in partial derivatives where needed now? You only need to insert two [itex]\underrightarrow{\partial}[/itex]'s, then all your equations are perfect.
I am a bit confused. I understand the desire to conserve arrows and the fact that a function is a 0-form but I would have expected you to write this asgarrett said:Ah, yes, mathematicians often write a vector operating on a function as [itex]\vec{v}f = v^i \partial_i f[/itex]. I do not write it that way. Instead, I would write the same thing as
[tex]
[/tex]
nrqed said:I am a bit confused. I understand the desire to conserve arrows and the fact that a function is a 0-form but I would have expected you to write this as
[tex]
\vec{v} \underrightarrow{ f} = v^i \partial_i f
[/tex]
no?!
In the way you wrote it, what do you mean by [itex] {\vec v}[/itex] ? Normally one would write [itex]{\vec v} = v_i \partial_i [/itex] but your partial derivatives are part of the 0-form?!?
garrett said:OK, so at this point we've figured out quite a bit about our group manifold.
... even though we haven't said what the metric is. Time to change that!
Mathematically, a vector field is Killing iff the Lie derivative of the metric with respect to the vector field is zero.
Taoy said:Can you explain how to talk about the metric in your notation? The metric tends to be formulated as, [itex] g = g_{ij} dx^i \otimes dx^j[/itex], however your [itex]\underrightarrow{dx^i} [/itex] basis elements are antisymmetric, not symmetric. How do you define this?
Of course, operating on a scalar, the lie derivative is equivalent to the covariant derivative, reducing to the expression I mentioned early on, [itex] \xi_{i;j} + \xi_{j;i} = 0 [/itex]. Can you give me some hints as to how to derive the expression for the lie derivative acting on the viel-bein? (We've not mentioned covariant derivatives yet!).
garrett said:Let me give you some of the cast of characters:
coordinate basis vectors:
[tex]
\vec{\partial_i}
[/tex]
coordinate basis 1-forms:
[tex]
[/tex]
partial derivative operator with respect to a coordinate:
[tex]
\partial_i
[/tex]
OK, with those guys, we can build vectors:
[tex]
\vec{v} = v^i \vec{\partial_i}
[/tex]
forms:
[tex]
\underrightarrow{f} = f_i \underrightarrow{dx^i}
[/tex]
and the exterior derivative operator:
[tex]
\underrightarrow{\partial} = \underrightarrow{dx^i} \partial_i
[/tex]
There is a contraction rule between basis vectors and basis forms:
[tex]
\vec{\partial_i} \underrightarrow{dx^j} = \delta_i^j
[/tex]
That's it!
Now, for some examples. A vector contracted with a 1-form:
[tex]
\vec{v} \underrightarrow{f} = v^i f_i
[/tex]
The exterior derivative of a 1-form:
[tex]
\underrightarrow{\partial} \underrightarrow{f} = \underrightarrow{dx^i} \underrightarrow{dx^j} \partial_i f_j
= \underrightarrow{\underrightarrow{F}}
[/tex]
And the derivative of a 1-form along a vector, obtained by first contracting the vector with the exterior derivative:
[tex]
( \vec{v} \underrightarrow{\partial} ) \underrightarrow{f}
= ( v^i \partial_i f_j ) \underrightarrow{dx^j}
[/tex]
Happy?
Mehdi_ said:Garrett can you explain please what is the difference between a killing vector field and a killing form.
I mean how to use a killing form to find a killing vector field.
garrett said:Hey Joe, you figure out the metric yet?
If not, I'll post it in the morning.
garrett said:OK, once you believe all this, which may take a while, I'll have three "homework" questions for you:
1) Are the set of three [itex]\vec{\xi'_B}[/itex] also Killing, even though we've chosen them as our orthonormal basis vector fields? (Why?)
2) What is the metric, [itex]g_{ij}[/itex] corresponding to this choice of orhonormal basis vectors?
3) Would the metric have been different if we had chosen to use [itex]\vec{\xi_B}[/itex] as the orthonormal basis vectors?
Wow, MG11 looks cool -- have fun.
Taoy said:It should be. I'm primarily here because tomorrow David Hestenes is hosting a parallel session on Geometric Algebra and Gravity; Doran and Lasenby are here too apparently. I'm hoping to find some people who are into the conformal projective framework... I'll definitely let you know how it goes :).
Great.Taoy said:Hey Garrett, finally found some wireless connectivity here at Freie University, Berlin; and for my sins I stayed up last night until I'd done my homework... yes;
OK, we'll see how that works out... ;)I'm coked up on coffee to make up for it :).
Yes. Except your wording is funny. The relevant equation is:I think that the answer is yes, because [itex] {\cal L}_{\vec{\xi'_A}} \vec{\xi'_B} = 2 \epsilon_{ABC} \vec{\xi'_C} [/itex], and for a fixed B, the right hand side is antisymmetric in A and C, and so like rotation - it therefore fulfils the requirement for a killing vector.
Nope, actually they are also Killing.However, the [itex]\vec{\xi_A}[/itex] fields are non-killing vectors with respect to this metric;
You answer this below -- both choices of orthonormal basis vectors produce the same metric.BUT we can also form a metric out of these other fields, and they are killing vectors with respect to that metric. We appear then to have two independant metrics that this manifold can support.
Yes, this is what I got for the "inverse metric":I believe it is,
[tex]
g'_{ij} = \frac{r^2}{\sin^2 r} \delta_{ij} + x_i x_j \left(\frac{1}{r^2} - \frac{1}{\sin^2 r} \right)
[/tex]
Correct! So, choosing either set of Killing vector fields to be the orthonormal basis vectors gives the same metric for SU(2). I like to choose [itex]\vec{e_A}=\vec{\xi'_A}[/itex] because they have the nice property that [itex]{\cal L}_{\vec{\xi_A}} \vec{e_B} = 0[/itex], and the [itex]\vec{\xi_A}[/itex] Killing vector fields have the same commutation relations as the su(2) generators, [itex]T_A[/itex].The difference in sign of the [itex]\epsilon[/itex] term doesn't contribute to a change in the form of [itex]g_{ij}[/itex] under the replacement of [itex]\vec{\xi'_A}[/itex] with [itex]\vec{\xi_A}[/itex].
