Expressing moment of inertia in terms of m,a,r and g
The discussion focuses on deriving the moment of inertia (I) of a platform in terms of mass (m), acceleration (a), radius (r), and gravitational constant (g). The key equations involve net force and torque, with the relationship between tension (T), mass, and acceleration being central to the solution. The final expression for moment of inertia is confirmed as I = (g/a - 1)mr^2 after a series of algebraic manipulations. Participants emphasize the importance of clear algebraic presentation for better understanding. The solution is validated, highlighting the collaborative effort in resolving the problem.
GMontey
Find an expression for the moment of inertia (I) of the platform in terms of acceleration of the mass (a), the value of the hanging mass (m), the radius of the spindle (r) and the constant (g).
Diagram: http://i.imgur.com/rv3zFYG.jpg
F=ma t=Iα a=rα
Net force: mg-T=ma (T is tension of spring)
Net torque: T-tf=Iα (T is tension of spring, tf is torque)
T=1/2ma
Apparently the answer is: I= (g/a-1)mr^2 but I'm having some trouble getting there.
tension in the what? "string" perhaps?
Net torque: T-tf=Iα
T is not a torque so you cannot subtract a torque from it - dimensions don't match. What is the relationship between torque and force?
T=1/2ma
How did you get that?
You have the right approach - start with free-body diagrams for each element.
But you need to be careful about your math.
i.e. for the mass: +ve = "down": ##mg-T=ma##
i.e. how many torques are acting on the flywheel?
How did you calculate T=1/2ma?
Also note that tf=T*rWELCOME TO PF!
I believe I solved it thanks to all of your help. The forces acting on the mass are gravity (mg) and the tension of the string (T). There is one torque acting on the spindle ( tf). The net torque on the mass is mg - T= ma which can be rewritten as T= mg - ma. The net torque on the spindle is tf =Iα. tf can be rewritten as Txr and I can substitute mg - ma for T, so now I have (mg - ma)xr =Iα. a =αr and I can rearrange this so α =a/r, which I can then substitute into (mg - ma)xr =Iα. Now I have (mg - ma)xr =I(a/r), using some algebra I can rearrange the equation into (mg - ma)xr x(r/a). Now I have (mg - ma)r^2/a, with more algebra I have (mg/a-ma/a)r^2 =I which simplifies to [(mg/a)-m]r^2= I. I pull out m and have (g/a-1)mr^2 =I, please tell me this is right...?
Well done - though it's a little hard to read.
I'd have just left it as $$I=\frac{g-a}{a}mr^2$$ but it is nice if it looks like the model answer.
(you want the mr^2 together because that is the moment of inertia of a point mass...)
Just a tip - it is easier to read your algebra if you lay it out like you would when you write.
i.e give each statement it's own line like this:
T= mg - ma
(mg - ma)xr =Iα.
Now I have
(mg - ma)xr =I(a/r)
... using some algebra I can rearrange the equation into (mg - ma)xr x(r/a).
Now I have
(mg - ma)r^2/a
... with more algebra I have
(mg/a-ma/a)r^2 =I
... which simplifies to
[(mg/a)-m]r^2= I
... I pull out m and have
(g/a-1)mr^2 =I
Huzzah! Thank you very much for both helping me and organizing my mess!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
