MHB Expression containing coefficients of a quadratic equation
The discussion revolves around finding the expression \( a^4 - 549a \) where \( a \) is the smallest root of the quadratic equation \( x^2 - 9x + 10 = 0 \). The factorization of the polynomial leads to the conclusion that \( a^4 - 549a + 710 = 0 \). This implies that \( a^4 - 549a = -710 \). The solution successfully avoids calculating the actual roots of the quadratic equation. The final result is \( a^4 - 549a = -710 \).
Evgeny.Makarov
MHB
Let $a$ be the smallest root of the equation $x^2-9x+10=0$. Find $a^4-549a$. Extra credit if the solution does not find the actual roots of the equation.
Mathematics news on Phys.org
[sp]The factorisation $x^4 - 549x + 710 = (x^2-9x+10)(x^2+9x+71)$ shows that if $a$ is a root of $x^2-9x+10=0$ (it could be either of the roots, not necessarily the smaller one), then $a^4 - 549a + 710 = 0.$
Therefore $a^4 - 549a = -710.$[/sp]
Correct.
$$(a^2+9a-10)(a^2-9a+10)=0$$
$$a^4-9a^3+10a^2+9a^3-81a^2+90a-10a^2+90a-100=0$$
$$a^4-81a^2+180a-100=0$$
$$a^4+180a-729a+729a=81a^2+100$$
$$a^4-549a=81a^2-729a+100$$
$$a^4-549a=81\left(a^2-9a+\dfrac{100}{81}\right)$$
$$a^4-549a=81\left(-10+\dfrac{100}{81}\right)=-710$$
which holds for either root.
My solution:
We are given:
$$x^2=9x-10$$
Square:
$$x^4=81x^2-180x+100$$
Subtract through by $549x$:
$$x^4-549x=81x(x-9)+100$$
But, we are given $x(x-9)=-10$, hence:
$$x^4-549x=81(-10)+100=-710$$
Because of the squaring, this holds for all roots of:
$$\left(x^2-9x+10\right)\left(x^2+9x-10\right)=0$$
we have $a^2= 9a - 10$
Hence $a^4 = a(a(9a-10)) = a(9a^2- 10a) = a (9(9a-10)- 10a)= a(71a - 90)$
$= 71a^2 - 90 a = 71(9a-10) - 90 a = 549a - 710$
or $a^4-549a = - 710$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
