Extension Spring Force Calc: Diam/Len for 5lb Proj 25-30ft
To determine the correct diameter and length of extension springs for a projectile device that propels a 5lb weight 25-30ft, it's essential to calculate the required spring constant based on conservation of energy and projectile motion principles. The discussion emphasizes the need to work backward from the desired range to establish the necessary muzzle velocity and kinetic energy. Understanding the relationship between the spring constant and the dimensions of the springs is crucial, as this will dictate the specifications for each spring in the system. The calculations should consider the effective spring constant for the combination of springs and how individual spring dimensions affect this value. Accurate determination of these parameters is vital for achieving the desired propulsion.
Z-inc
I need to determine the correct diameter and length of a combination of 4 extension springs to use in a projectile device. The springs must be able to extend to approx 3ft, and generate enough force to propel a set of objects that are 3ft in length and have an overall weight of approx 5lbs. The objects must be propelled approx 25-30ft.
Welcome to PF;
There is not enough information to answer your question.
You need to know how the spring constant of each spring depends on the diameter and length of the springs in question and how you are going to combine the four of them.
You can work out a ballpark spring constant requirement from the data using conservation of energy and a model for the projectile motion.
Extension Spring
I want to use two extention springs on either side of a metal bar to propell a 5lb weight 25 -30ft. I need to determine the diameter and length of the springs that will provide enough force to propell that 5lb object. Therefore, I don't know the spring constant. I'm not sure if that helps in what I am asking for.
Thanks for the reply.
You can work out what the spring constant needs to be using conservation of momentum and ballistic equations.
Work it backwards:
You know the maximum range ... what angle gives you the max range?
What muzzle velocity is needed at that angle to get the needed range?
(What were the assumptions and are they reasonable?)
From the muzzle velocity - what is the kinetic energy?
What is the equation for the amount of energy stored in a spring system with effective spring constant k? ... What is k?
This will be the spring constant for the system of two springs so - knowing k for the combination, what is k for each spring?
Now you know what each spring needs to be able to pull.
How is the spring constant related to the diameter and length of the springs?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
11K
10K
