Extinction law -- How big is the extinction in the H-band?
  • Thread starter Thread starter CharlesDamle
    Extinction Law
The discussion focuses on understanding the extinction law in the H band, specifically how to calculate the extinction using the formula A_H = 0.591 * E(B - V). The user expresses confusion about the relationship between the B and V bands and the relevance of the H band wavelength. Clarifications are provided that E(B-V) can be derived from known extinction values in the V-band, allowing for the calculation of extinction in the H-band. Ultimately, the user successfully resolves their confusion and figures out the problem.
CharlesDamle
E(B-V) = A_B - A_V
Hey, I'm totally blank on this problem, and I'm not even sure what to solve for.
I'm told that the H band, which is in 1.63 μm, has an extinction law A_H = 0.591 * E(B - V) and I'm supposed to answer how big the extinction is in the H band.
And I'm confused because it involves the difference between the B and V band, and I'm not sure why I should use the wavelength of the H band. I'm tempted to say it is just 0.591
I'd appreiate any input.
Thank you for the links.
No, it doesn't the equation, just states it in the introductory chapter.
So are you able to solve the problem now?
Yes, I figured it out :)
Likes phyzguy
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
