Extracting carbohydrates from food dissolved in hydrochloric acid
  • Thread starter Thread starter bobdavis
    Acid Food
The discussion centers on simulating the digestive process using hydrochloric acid to extract carbohydrates from food, aimed at creating an engaging science experiment for kids. It acknowledges that food is dissolved in hydrochloric acid in the stomach, leading to the extraction of carbohydrates for cellular respiration. The concentration of hydrochloric acid in the stomach is approximately 0.16 M/L, but the experiment may not require direct interaction with the acid for safety reasons. An alternative demonstration involves using iodine to show starch conversion to sugar, where iodine turns blue in the presence of starch and remains orange when sugars are present. This experiment highlights the role of the amylase enzyme in saliva, with a cautionary note against ingesting iodine.
bobdavis
I know that food is dissolved in hydrochloric acid in the stomach, and carbohydrates are eventually extracted for use in cellular respiration which if I understand correctly is essentially a complex combustion reaction, using oxygen and releasing CO2.
Outside the stomach, I can partially simulate the process of digestion by putting food into a hydrochloric acid solution. Is there a way to extract combustible carbohydrates from the reaction products? It doesn't necessarily need to mirror the actual processes used by the body or be energy efficient, it's just for a fun science experiment for kids
Chemistry news on Phys.org
What concentration of hydrochloric acid will these kids be working with?
If I understand correctly the concentration in the stomach is ~0.16 M/L, but also I'm not necessarily intending for kids to actually work with the acid, just to show
There is a demonstration of starch conversion to sugar using iodine. Iodine turns blue in the presence of starch and remains orange in the presence of sugars. This demo relied on the amylase enzyme in saliva. A couple of drops of iodine onto a Saltine cracker turns blue but if the student chews the cracker first and let's the mush set a bit, adding a couple of drops of iodine remains orange.
Remember not to ingest iodine!
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
