B F=ma Applied to a Billiards Cue
The weight of a billiards cue affects the force applied to the cue ball during a break, with heavier cues potentially providing more momentum if the player can handle them effectively. Optimal cue weight varies based on the player's strength and biomechanics, as a cue that is too light may lack sufficient momentum, while a cue that is too heavy may hinder speed. The relationship between cue weight and shot precision is crucial, especially for power shots like breaks. A heavier cue can enhance cue ball speed with less effort, but control over finesse shots may favor lighter cues. Ultimately, players should choose a cue weight that feels comfortable and allows for effective stroke adjustment.
tmlesko
TL;DR Summary
Is it correct to apply F=MA to answer the question: can a heavier cue stick apply more force in breaking a rack of billiards balls? Assuming all material factors remain the same, there any other factors involved?
Many years ago, I was asked if the weight of a billiards cue matters when breaking a rack of billiards balls. I.e. does a heavier cue apply more force to the cue ball. (typically the range of a break cue is 18-25 oz.) So, probably obviously, I used the formula F=MA as an explanation. RecentlyI was asked that question again, and I am left wondering, given that the materials and other elements remain constant, if I am correct? Would any other factors enter in?
Thanks, new member here.
Tom L.
:welcome:
I suggest there is an optimum weight of cue depending on the strength of the player and their power and speed characteristics.
If a cue is too light, then it may be difficult to give it sufficient momentum. And if it's too heavy, then the player may struggle to move it quickly enough.
Any sophisticated model would have to take the player's biomechanics into account.
Likes jbriggs444, berkeman, russ_watters and 1 other person
It's not really a physics question here, it's a biomechanics question, because the question depends on how well you can use a heavier versus lighter cue.
The outcome you want is that the cue ball travels faster, but without sacrificing precision. A heavier cue will probably be better as long as you are strong enough to accelerate it to the same speed as the lighter one, with the same precision, and the cue is similarly rigid. A great big gorilla of a bloke is going to see more improvement from a heavier cue than a lightly built kid because he'll be able to accelerate it fast while the kid might struggle to provide the power accurately.
Maybe, rather than F=ma, the problem could be viewed from a kinetic energy perspective. The energy of the cue is transferred to the cue ball, that is then shared or cascaded to many balls on the table.
Somebody studied the physics of it. There is a URL at the end of the document that explains in more detail the impact of the physiological factors and personal techniques involved.
https://billiards.colostate.edu/bd_articles/2015/oct15.pdf said:
For your main playing cue, you should use whatever weight feels most comfortable. Different weights can produce slightly different results; but with practice, one can get accustomed to a cue of any weight. You will learn to adjust your stroke as necessary to achieve the range of cue speeds appropriate for different shots. The only shots for which cue weight can make a significant different are power shots (e.g., an extreme power draw, or the break shot), as discussed later in the article.
In general, a lighter cue will allow more control over finesse shots, and a heavier cue will allow more cue ball (CB) speed with less apparent stroke effort. A heavier cue might also be easier for some people to keep on line during the stroke, but this is a very individual thing. Also, a heavier cue might tend to have a shaft with more endmass (the weight of the portion of the shaft closest to the tip); although, this isn't necessarily the case. If it is, the heavier cue will create more squirt (AKA "cue ball deflection"), which can have both advantages and disadvantages for different people.
Likes berkeman, russ_watters, anorlunda and 1 other person
PeroK said:
:welcome:
Thank you, much appreciated.
Tom L.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
