F'(x) = 2x(f(x)) and f(2) = 5, find
  • Thread starter Thread starter LearninDaMath
The discussion revolves around solving the differential equation f'(x) = 2x(f(x)) with the initial condition f(2) = 5, and subsequently finding g'(π/3) where g(x) = f(sec x). Participants express confusion about the problem's structure, particularly regarding the composition of functions and the application of the chain rule. Clarifications indicate that the problem is designed to test understanding of these concepts, with sec(π/3) equating to 2, which directly relates to the given condition f(2) = 5. The conversation highlights a desire for more practical applications of such mathematical problems to better understand their relevance.
LearninDaMath
f'(x) = 2x(f(x)) and f(2) = 5, find...
Suppose that f'(x) = (2x)(f(x)) and f(2) = 5
Find g'(∏/3) if g(x) = f(secx)
no idea
:confused:
No idea where to begin but i'll give it a try...
nothing comes to mind...i don't know where to start...
before I attempt to solve, can anyone explain what this question even means? or point me in the direction to some online source that explains this...I would greatly appreciate it.
I never had a problem where there was a function of the form f(x) within a derivative function statement.
no idea
:confused:
If f(x) = y, f'(x) is another way of denoting dy/dx (the derivative).
Can you do the question now? The first part involves setting up a simple differential equation. Once you've found an expression for f(x), the second part just involves differentiating f(sec x) (using Chain Rule) and substituting pi/3 into the result.
You're asked to find g'(π/3). That's obviously the value of the function g' at π/3. So you need to find the function g', and then insert π/3 into it. You haven't been told what g' is, but you've been told that ##g=f\circ\sec##. g' is the derivative of g, so the first step is obviously to find the derivative of g. Since g is a composition of two functions, you have to use the chain rule.
Got it, thanks! Is there any useful application of a problem of this nature?
Sorry about my previous post, I was at work and rushing and did not read the question carefully enough. There's a much simpler way to do the problem, as you've no doubt figured out with Fredrik's help. Of course, solving directly for f(x) will also give you the same answer, it's just a little more tedious.
This sort of problem is usually constructed "just so" in order to test your application of concepts. So sec(pi/3) here will equal to 2, which is why you're given f(2) in particular so that all the pieces fit well, and you can quickly arrive at a solution. In real life, it's not usual to find problems so neatly constructed.
No prob at all, I'm always appreciative of the help given by you and others. Regarding you second paragraph, it's interesting that there seems to be (aside from the problems, like this one, meant to just test understanding of the computational concept) a slight disconnect between the physical representation and the graphical representation for the problems in the book. I continue to solve various derivative problems, but I would like to see what they mean if translated to some physical example. And visa versa, there are many physical problems in the book, such as the sliding ladder (that I recently posted), in which I am interested to see how that would be represented graphically.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
