MHB Factor: bca² + bcd² + adb² + adc²
  • Thread starter Thread starter SweatingBear
    Adc
The expression bca² + bcd² + adb² + adc² can be factored into (ab + cd)(ac + bd). Initial attempts at factoring by grouping were unsuccessful, but through trial and error, a successful strategy was identified. Grouping terms and factoring out common elements led to the correct factorization. The discussion emphasizes that non-trivial factoring often requires persistence and experimentation. Ultimately, the solution highlights the importance of practice in mastering such mathematical challenges.
SweatingBear
The task is to factor
$$bca^2 + bcd^2 + adb^2 +adc^2$$,
which undeniably is a non-trivial one. It turns out that the expression can be factored into $$(ab + cd)(ac + bd)$$. I have absolutely no idea what strategy to employ in non-trivial cases such as these (although I did attempt factoring by grouping, however to no real avail). Forum, got any clues/suggestions/tips? Anything helps!
Mathematics news on Phys.org
try to group it
= bc(a^2+d^2) + ad(b^2 + c^2)
no
bca^2 + adb^2 + bcd^2 + adc^2
= ab( ac+ bd) + bc(bd + ad) ( I got it)
= ( ac+bd)(ab+ cd)
it is done
did you miss something
Essentially it comes down to trial and error and practice.
I would seek to factor $$bc $$ from the first two terms and $$ad$$ from the second two simply because they stand out to me.
$$bc(a^2+d^2) + ad(b^2+c^2)$$. This just leads to a dead end though.
Let's try $$ab$$ and $$cd$$ respectively (some question setters aren't very imaginative (Wink))
$$ab(ac +db) + cd(bd + ac) = ab(ac+bd) + cd(ac+bd)$$
Now I have $$ac+bd$$ in both terms I can factor again to get the answer:
$$(ac+bd)(ab+cd)$$
Thanks a lot, looks like trial-and-error will have to do.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
