Factoring Imaginary Numbers in a 2x1 Matrix: Solving the Physics Problem
NutriGrainKiller
This is a physics problem but I am having trouble factoring this matrix. Basically, there shouldn't be anything left inside the matrix except 0's, 1's, or i's (any of which can be negative). This seems like such an easy problem but I cannot find something that works.
Any ideas?
<br /> <br /> \frac {1} {2\sqrt{2}}<br /> <br /> \left(\begin{array}{cc}1+\sqrt{3}\\1-\sqrt{3}\end{array}\right)<br /> <br />
in case anyone finds this confusing this is a 2 row 1 column matrix.
bumping because i just now got the latex to display properly
couldnt you simply subract the rows from each other??
Why do you think it can be put into that form?
No I don't think so
because the inside can only result in one of several cases, all of which contain only 0's, 1's, or imaginary numbers. anything else wouldn't make sense
Then maybe this is a spurious solution. What were you actually solving?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
