Faraday's Law and magnetic flux
The discussion centers on whether an induced current will occur in a circular coil when a magnetic field changes, given that the magnetic field does not pass through the coil. One participant argues that no induced current will result because the magnetic field is not intersecting the coil. Another perspective suggests that if the magnetic field is oriented along the axis of the coil, a potential could still be generated, similar to isolation transformers. The conversation highlights the importance of the magnetic field's orientation and the coil's configuration in determining the presence of induced current. Ultimately, the conclusion is that the relationship between the coil and the magnetic field is crucial for understanding induced current.
rickyw2777
If there is a circular coil of radius r0 and a circular region of magnetic field of radius r1. Given that them have the same center and r0>r1, if the magnetic field changed its magnetic field strength, will there still be a induced current?
E=delta Phi/delta t
I believe that there will not be a induced current because the magnetic field does not pass through the coil.
Can you make a nice drawing that shows how you came to the conclusion?
rickyw2777 said:
Homework Statement: If there is a circular coil of radius r0 and a circular region of magnetic field of radius r1. Given that them have the same center and r0>r1, if the magnetic field changed its magnetic field strength, will there still be a induced current?
Relevant Equations: E=delta Phi/delta t
Assuming that the field direction is along the axis of the coil (not defined in the question as stated here*), there will be a potential generated in the coil. This is exactly what happens in isolation transformers. The current depends on how the coil is connected.
*My assumption is that the coil and the field circle are coplanar, and the field is perpendicular to the disc of the circle.
However, you could read this as the field being along the circumference of the circle, in which case your original thoughts would apply.
I wonder where does the homework and you are looking at ? No charge, no current.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
