Faulted demonstration of orthonormality in my textbook?
LeFH18
Show that the functions:
ψ_m(θ)= (2π)^(-1/2) e(imθ), m = 0, +- 1, +-2, ...
form an orthonormal set over the interval (0,2π)
Function set:
Orthonormality condition:
int( ψ*_m ψ_n dx) = δ_nm
where δ is Kronecker's delta
The textbook, "Mathematics for Physical Chemistry - Opening doors" (McQuarrie), solves this example excercise as follows:
And is the case for n =/= m which I'm troubled with, because, if I solve the integral instead of using the cycles argument, I get that:
And I can't see how this is equal to zero. Any leads on why this must be zero for n unequal of m?
Euler's identity says ##e^{i \varphi}=\cos \varphi + i \sin \varphi.## Now substitute ##\varphi = 2\pi (n-m) .## Orthogonality of two vectors ##v_m, v_n## means ##\bigl\langle v_m,v_n \bigr\rangle =\delta_{mn}.## It's the definition, whether ##v## are vectors or functions, and whatever the inner product is defined as, in this case by an integral.
Likes LeFH18 and FactChecker
Thank you so much!
I did not realize that I could do that substitution. Doing that, I get the following:
## = \frac{i}{\varphi}(1-e^{\varphi i})##
Expanding it into cosine and sine, and noting that ##(n-m)## is always an integer because ##n## and ##m## also are integers, it leads to the inner product being zero.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
