Faulty approach to solving a double Atwood's machine
The discussion focuses on a faulty approach to solving a double Atwood's machine problem. The original poster derives an expression for the acceleration of mass m1 but realizes it is missing a term in the denominator compared to the reference solution. The error is identified in the application of the conservation of string, specifically the assumption that a2 = -a3 holds universally. It is clarified that this relationship only applies in the reference frame of the pulley, not from the ground perspective. The conversation emphasizes the importance of correctly applying the principles of mechanics to avoid such mistakes.
Rations
Hello. I'm wondering why my approach to solving this problem (Morin 3.2) is faulty.
A double Atwood's machine is shown, with masses ##m_1##, ##m_2##, and ##m_3##. Find the accelerations of the masses.
##F = ma##
Let's say the string over the bottom pulley has tension ##T## and the string over the top pulley has tension ##T_2##. Assuming that the pulleys and ropes are massless and defining the upwards direction as positive, I have several equations:
(1) For ##m_1##: ##T_2 - m_1g = m_1a_1##
(2) For ##m_2##: ##T - m_2g = m_2a_2##
(3) For ##m_3##: ##T - m_3g = m_3a_3##
(4) For the lower pulley: ##T_2 - 2T = 0##
(5) From conservation of string: ##a_2 = -a_3##
If I substitute ##-a_3## into (2) and then solve (2) and (3) for ##T##, I find ##T = \frac{2m_2m_3g}{m_2 + m_3}##. From (4), ##T_2## is twice this value.
Then, I substitute my expression for ##T_2## into (1) and solve for ##a_1##, which yields:
a_1 = g\frac{4m_2m_3 - m_1(m_2 + m_3)}{m_1(m_2 + m_3)}
This answer is close to what Morin writes, but is missing a term in the denominator. After reading his solution, which uses the fact that ##a_1 = -\left(\frac{a_2 + a_3}{2}\right)##, I feel that I can understand why his approach works. However, I do not see where I made a mistake.
Rations said:
From conservation of string: a2=−a3a_2 = -a_3
This is where you have made a mistake . Why ?
Conservation of string can be looked at in two ways .
Since you use all accelerations in one direction , this would be an easier way to understand -
Total power by string must be zero ( Why ? ) . Power = F.v , so total sum of of each individual power provided by string must be equal to zero .
So 2T*v1 + T*v2 + T*v3 = 0 , or ,
2v1 + v2 + v3 = 0 .
So what relation do you get for acceleration ?
I hope this helps .
Oh, right. I just realized that ##a_2 = -a_3## only holds in the reference frame of the pulley, not the ground. Don't know why that point eluded me for so long. Thanks.
##F = ma##
Your error is with the equation you get from the "conservation of string", as Qwertywerty points out.
A simple way to see that this is erroneous is: Suppose that m2 = m3 . Then we must have a2 = a3 , but these won't be zero in general.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
