Few Questions on source tranformation
When different voltage sources are in series, the resultant voltage is the sum of the sources, considering their polarities, rather than simply picking the smaller one. The initial conversion of 1A and 2 ohms to 2V is incorrect as the resistance does not disappear; the solution likely mislabels a resistor. The confusion regarding the disappearance of resistance arises from the parallel configuration of resistors, which can be replaced by an equivalent resistance. The discussion highlights the importance of proper labeling and understanding circuit configurations. The thread suggests a need for relocation to the homework sub-forum for better assistance.
clurt
It's question 1b) Please view attached
1. Just to clarify, when different voltage sources are in series you pick the smaller one?
2. First step, they turned the 1A and 2ohm into 2V, why does the resistance disappear? Then between the last two steps the 12/7 ohm resistance remains with 18/7 voltage. Why does one resistance disappear while the other doesn't?
Thanks on advance
It would have been better if you'd cropped the attachment to just the relevant block in post #1 and in the process made it more legible.
No! The 3v comes about because two sources are in series, +6v and -3v, so the resultant voltage is their sum with polarities taken into account.
It doesn't. The solution is in error. I expect the right side 2 ohm was probably intended to be labelled 4 ohms.
Nothing disappears. The two resistors are in parallel, so they can be replaced by an equivalent one of the value equal to that when two resistors are in parallel.
Hope that helps.
This thread belongs in the homework sub-forum. You almost certainly would have received prompt assistance had you listed it there.
Could a mentor kindly move this to the appropriate forum ...
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
