latentcorpse
- 1,444
http://www.damtp.cam.ac.uk/user/tong/qft/qft.pdf
Consider the Feynman rules for Green's Functions given at the top of p79 in these notes.
Now let us consider the diagram given in the example on p78.
Take for example the 2nd diagram in the sum i.e. the cross one where x1 is joined to x4 and x2 is joined to x3 and these two lines cross over each other.
Suppose I wanted to apply the Feynman rules to this diagram:
I am not sure if the point where they cross is a vertex or not? I'm going to assume that it must be otherwise that diagram would be the same as the 1st one in the sum (but with vertices relabelled). So let us label the vertex with the spacetime position y.
The Feynman rules then tell us that this Feynman diagram contributes
[itex]-i \lambda \int d^4y \int \frac{d^4k}{(2 \pi)^4} \frac{i e^{-ik \cdot (x_1-x_4)}}{k^2-m^2+i \epsilon} \int \frac{d^4p}{(2 \pi)^4} \frac{ie^{-ip \cdot (x_2 - x_3)}}{p^2-m^2+i \epsilon}[/itex]
Is this correct? Can it be simplified? It looks pretty messy?
Presumably when we added the other contributions from all the other diagrams, we'd end up with a nice final expression for [itex]G^{(4)}(x_1 , \dots , x_4)[/itex]?
Thanks.
Thanks.
