Field between 2 conducting spheres in electric field
The discussion focuses on the behavior of the electric field between two conducting spheres placed in a constant electric field. Simulations indicate that the electric field in the gap increases with the diameter of the spheres while maintaining a constant gap distance, which contradicts initial expectations. An analytical solution is derived using the concept of induced dipoles, resulting in a formula that aligns with the simulation results. The induced dipole moment of a conducting sphere in an electric field is calculated, leading to a specific expression for the electric field at a certain distance from the dipole. The conversation concludes with a confirmation of the derived results and their qualitative agreement with the simulations.
oliverroth
Hi,
I tried to make some simulations of two conducting spheres in a constant electric field. The simulations seem to indicate that the electric field in the gap increases with increasing diameter of the spheres at a constant gap distance. Does this make sense? I expected just the reverse. What is wrong? Does an analytical solution for this problem exist?
I really appreciate any help.
If I approximate the added field at the center of the gap as due to two induced dipoles,
I get E=\frac{4E_0}{(1+d/2R)^3}. This agrees with what you found.
Thanx a lot. This matches qualitatively (although it still sounds odd to me). Can you tell me how you have derived this result?
A conducting sphere in constant electric field E_0 gets an induced dipole moment
p=E_0 R^3.. The electric field a distance R+d/2 from a dipole is
E=2p/(R+d/2)^3. Put these together to get the answer.
Ok. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
