MHB Field lines of 3D vector functions
brunette15
My question regards finding the field lines of the 3D vector function F(x,y,z) = yzi + zxj + xyk.
I was able to compute them to be at the curves x^2 - y^2 = C and x^2 -z^2 = D, where C and D are constants.
From my understanding the field lines will occur at the intersection of these two curves, however I am struggling to understand why the field lines occur at the intersection. If anyone can please just clarify or give me more of an insight as to what is actually happening with the field lines of this vector function that would be very helpful :)
Hi brunette15! ;)
If we pick a point on the intersection curve and consider it part of a field line, we can try and see in which direction that field line has to go.
The normal of the first surface is given by the gradient of $x^2 - y^2$, which is $2x\boldsymbol{\hat\imath} - 2y\boldsymbol{\hat\jmath}$.
That just happens to be perpendicular to the given direction $\mathbf F(x,y,z)$ of a field line, which we can tell from their dot product, which is zero.
The same holds for the second surface.
In other words the direction of the intersection curve is parallel to the direction of the field line.
That means that the field line coincides with the curve of intersection.
I like Serena said:
Hi brunette15! ;)
That helps a lot! Thankyou so much! :D
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
