michelcolman
- 176
- 2
Don't reply too quickly, I've seen a lot of answers on this question already (differing ones of course, what would you expect), at first sight it would seem to be really simple but there are quite a few complicating factors.
So the question is basically: what's the quickest way to fill up a pool with a garden hose. Hose just above the water level, hose just below the water level, or hose well below the water level? Or does it make no difference? (Hose far above the water level will obviously be slower as the output pressure of the hose will decrease much more than the air pressure from altitude)
From a pure pressure point of view, submerging the hose should make no difference: as the end of the hose is placed deeper under water, the output pressure of the hose will become higher but the opposing pressure from the water in the pool will increase by the same amount.
However, intuitively it seems easier for water to push air out of the way rather than other water. The submerged hose also creates a vortex in the water, and that energy has to come from somewhere too.
Also, when water exits the hose vertically in the air, gravity on the open water stream will accelerate it further and perhaps create extra suction (although that effect is probably less than what you would get from a lower exit point).
Some sites actually say that the submerged hose will have a slightly higher rate because of some kind of siphon effect, but I don't really understand how that would work.
Does anyone have a reliable answer, or is this just one of those things where every expert has a theory but nobody has actually bothered to check it rigourously?
Thanks for any insights!
Michel
Michel
