Finance Problem but its basic math, i just cant see it right now
  • Thread starter Thread starter Nawz
    Finance
The discussion revolves around solving a finance problem related to calculating the weighted average cost of capital (WACC). The correct formula is presented, leading to the conclusion that the weight of debt (wd) is 30%. The participant initially struggled with the calculations and resorted to plugging in answers to find the solution. They later clarified their method, realizing that the sum of weights must equal 100%, which helped them understand the relationship between wd and the weight of equity. The participant seeks to grasp the correct approach to the problem rather than relying on trial and error.
Nawz
A. 53%
B. 40%
C. 30%
D. 70%
E. 36%
Solution: WACC = wd kd (1 - T) + wsks ; 13.00% = wd (9% (1 - 0.35)) + (1 - wd) ($2(1.075)/$25.00 + 7.5%) ; Solve for wd = 30%.
ok, i got this one right but i did it by plugging in the answer becus i cld not figure it out. The formula for the answer how they do it is above but simplified i get this: .13=wd(.0585)+(1-wd)(.161)
wd comes out to be 30 percent.
i must be missing something because i can not figure it out
ok sweet i think i got it..
this is what i did.
13=5.85wd+16.1-16.1wd
-3.1=-10.25wd
wd=0.302439024
Since both must equal 100 in this problem. that is why they do 1-wd. What i originally did on the quiz was i just plugged in the answers wd and solved and then w/e was left must equal to 100. so using the 30 i got the common equity to be 70 percent when i plugged it in and BAM problem solved. I am just trying to figure out how the correct way was.
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
