MHB Find $a+b+c$ for Integer $a,b,c$ Given $a+b=2004$
  • Thread starter Thread starter anemone
    Integer
The problem involves finding the sum \( a + b + c \) for integers \( a, b, c \) given the equations \( a + b = 2004 \) and the relationships \( \frac{2a-b}{c} = \frac{2b+c}{a} = \frac{-2a-c}{b} \). By substituting \( k \) into the equations, it is determined that \( k = -1 \), leading to the conclusion that \( a = 3b \). Given \( a + b = 2004 \), solving for \( b \) yields \( b = 501 \) and consequently \( a + b + c = -501 \). The final result is \( a + b + c = -501 \).
anemone
MHB
POTW Director
For the integers $a, b, c$, we have $\dfrac{2a-b}{c}=\dfrac{2b+c}{a}=\dfrac{-2a-c}{b}$.
If $a+b=2004$, find $a+b+c$.
Mathematics news on Phys.org
Re: Find a+b+c
We have
(2a-b)/c = (-2a-c)/b
As (a/b= c/d = (a+c)/(b+d))
Have both = (2a-b – 2a –c)/(b+c) = -1
Furher from (2b+c)/a = (-2a –c) we get both =2 (b-a)/(b+a) = - 1
So
2(b-a) = - (b+a) = - 2004
Or b – a = - 1002
So a = 1503, b = 501
Now 2b+c = -a or c = - (2b-a) = - 2505
So a + b+c = - 501
(ratio a:b:c = 3:1:-5 and sum = -b)
Re: Find a+b+c
Hi kaliprasad, thank for participating and I particularly like the following "trick" that you used in your method to solve the problem!:cool:
If $ad=bc$, then
i$\dfrac{a+c}{b+d}= \dfrac{\frac{bc}{d}+c}{b+d}=\dfrac{\frac{c}{d}(b+d)}{b+d}=\dfrac{c}{d}$
$\;\;\;\;\;\;\;\;\;\;\overset{or}= \dfrac{a+\frac{ad}{b}}{b+d}=\dfrac{\frac{a}{b}(b+d)}{b+d}=\dfrac{a}{b}$.
My solution:
From the given equation $\dfrac{2a-b}{c}=\dfrac{2b+c}{a}=\dfrac{-2a-c}{b}$, we have:
[TABLE="class: grid, width: 500"]
[TR]
[TD]$\dfrac{2a-b}{c}=\dfrac{2b+c}{a}$[/TD]
[TD]$\dfrac{2a-b}{c}=\dfrac{-2a-c}{b}$[/TD]
[TD]$\dfrac{2b+c}{a}=\dfrac{-2a-c}{b}$[/TD]
[/TR]
[TR]
[TD]$2a^2-ab=2bc+c^2$[/TD]
[TD]$(b+c)(2a-b+c)=0$[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD]But notice that $b+c\ne 0$ because if $b+c=0$,
$2a^2-ab=2bc+c^2$ becomes
$2a^2-ac=-2c^2+c^2$
$2a^2-ac+c^2=0$
$2a^2-ac+c^2=0$
$2(a-\frac{c}{4})+\frac{7c^2}{8}\ne 0$ for all integers $a, c$.
Hence, $2a-b+c=0$[/TD]
[TD]$\dfrac{2b+c}{a}=\dfrac{-(2a+c)}{b}$
$\dfrac{2b+c}{a}=\dfrac{-b}{b}$
$2b+c=-a$
$a+2b+c=0$[/TD]
[/TR]
[/TABLE]
Now, solve the equations $2a-b+c=0$ and $a+2b+c=0$ by eliminating the variable $c$ for a and b, we get $a=3b$ and from $a+b=2004$, we obtain $a=1503, b=501, c=-2505$ and therefore $a+b+c=-501$.
Re: Find a+b+c
let :
$\dfrac{2a-b}{c}=\dfrac{2b+c}{a}=\dfrac{-2a-c}{b}=\dfrac {1}{k} , k\neq 0$.
then :
a=(2b+c)k----(1)
b=(-2a-c)k---(2)
c=(2a-b)k----(3)
(2)+(3) :b+c=(-b-c)k , so k=-1
(1)+(2)+(3): a+b+c=bk=-b
(1)+(2) :a+b=2a-2b , so a=3b
freom a+b=4b=2004 , b=501
we get a+b+c=-b=-501
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
