Find a diagonal matrix D such that the tridiagonal matrix T
crocomut
For a symmetric matrix B=B' where ' is the transpose.
Since we know that for a symmetric matrix,
B = B'
I attempted to substitude that in and tried to solve for D.
DTD-1 = (D-1)'T'D
DT = D-1T'DD
D = D-1T'DDT-1
At this point I am stumped since there are D's on both sides, what am I suppose to do?
Thanks a lot for your help.
Croco.
Code:
Seems to me you could just "write it out". Let x[subn[/sub] be the nth diagonal entry in D. Then 1/xn is the corresponding entry in D-1. Now, actually write out the entries for the product DTD-1. What must be true in order for that to be symmetric? If you are not sure how to do that, try it with 2 by 2 and 3 by 3 matrices first.
Notice, by the way, that saying "bici+1> 0" is exactly the same as saying "bi/ci+1> 0" or even "ci+1/bi> 0" because the only thing that is relevant is the sign: all three just say that neither of bi nor ci+1 is 0 and they have the same sign.
Hi HallsofIvy,
Thanks so much for your answer, I actually did it last night. Maybe you can have a look at my result and confirm:
In the end I got that the diagonal entries of D are:
di+1 = di\sqrt{b_i/c_{i+1}}
The square root is why bici+1 > 0
Croco
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
