MHB Find A Polynomial With Lowest Degree
  • Thread starter Thread starter anemone
    Degree Polynomial
The discussion centers on finding the polynomial of the lowest degree with integer coefficients that has the root $$\sqrt{2} + \sqrt[3]{3}$$. It is established that the minimum degree of such a polynomial is 6, derived from the degrees of the extensions $\mathbb{Q}(\sqrt{2})$ and $\mathbb{Q}(\sqrt[3]{3})$. The polynomial is expressed as $$x^6 - 6x^4 - 6x^3 + 12x^2 - 36x + 1 = 0$$. The reasoning involves Galois theory, demonstrating that both $\sqrt{2}$ and $\sqrt[3]{3}$ can be expressed in terms of the root. The final polynomial confirms the calculations and theoretical underpinnings discussed.
anemone
MHB
POTW Director
Find the polynomial of the lowest degree with integer coefficients such that one of its roots is $$\sqrt{2} + \sqrt[3]{3}$$.
Mathematics news on Phys.org
If $x = \sqrt{2} + \sqrt[3]{3}$ then $3 = (x-\sqrt2)^3 = x^3 - 3\sqrt2x^2 + 6x - 2\sqrt2$. Therefore $x^3 + 6x - 3 = \sqrt2(3x^2+2)$, and $(x^3 + 6x - 3)^2 = 2(3x^2+2)^2$. So $x^6 - 6x^4 -6x^3 + 12x^2 - 36x + 1 = 0.$
I hope that someone who knows a bit about Galois theory would be able to tell us why 6 is the minimum possible degree for such a polynomial.
$\because (\sqrt 2)^2=2 $
$\& (\sqrt[3]{3})^3=3 $ (both are integers )
$\therefore 6 =(2\times 3)$ is the minimum possible degree
for such a polynomial with integer coefficients
Right, but to spell it all out:
Let $\alpha = \sqrt{2} + \sqrt[3]{3}$·
First, it is equivalent to having a polynomial over $\mathbb Q$, indeed if $\frac{a_0}{b_0}+\frac{a_1}{b_1}\cdot \alpha + \ldots + \frac{a_n}{b_n} \cdot \alpha^n = 0$ (with $a_i\in {\mathbb Z}$ and $b_i\in {\mathbb Z}^+$) then $a_0 \cdot \left(b_1 \cdot \ldots \cdot b_n\right) + \ldots + a_n \cdot \left(b_1\cdot \ldots \cdot b_{n-1}\right) \cdot \alpha^n = 0$ and $\alpha$ would also be a root of an integer polynomial.
Next we prove that
\[{\mathbb Q} (\sqrt 2,\sqrt[3]{3}) = {\mathbb Q}(\alpha) \]​
We will prove that ${\mathbb Q} (\sqrt 2,\sqrt[3]{3}) \subseteq {\mathbb Q}(\alpha)$ since the other inclusion is trivial.
From Opalg's calculations we have \[3 = (\alpha-\sqrt2)^3 = \alpha^3 - 3\sqrt2\alpha^2 + 6\alpha - 2\sqrt2\] from where we can solve for $\sqrt 2$ in terms of $\alpha$ (and its powers) and rationals. Hence $\sqrt 2 \in {\mathbb Q}(\alpha)$
Finally, once you know $\sqrt{2} \in {\mathbb Q}(\alpha)$, it follows trivially that $\alpha - \sqrt{2} = \sqrt[3]{3}\in {\mathbb Q}(\alpha)$ and so $\sqrt[3]{3} \in {\mathbb Q}(\alpha)$.
Now it is not difficult to see that $[{\mathbb Q}(\sqrt 2,\sqrt[3]{3}) : {\mathbb Q}(\sqrt[3]{3})] = 2$.
Indeed $\sqrt 2 \not\in {\mathbb Q}(\sqrt[3]{3})$, because $ 3 = [{\mathbb Q}(\sqrt[3]{3}) : {\mathbb Q}] = [{\mathbb Q}(\sqrt[3]{3}) : {\mathbb Q}(\sqrt{2})] \times [{\mathbb Q}(\sqrt{2}) : {\mathbb Q}] = 2 [{\mathbb Q}(\sqrt[3]{3}) : {\mathbb Q}(\sqrt{2})]$ is absurd since $2\not | 3$, and so $x^2 - 2$ has no roots in ${\mathbb Q}(\sqrt[3]{3})$. Thus $x^2 - 2$ is the irreducible polynomial for $\sqrt 2$ over ${\mathbb Q}(\sqrt[3]{3})$ and we have $[{\mathbb Q}(\sqrt 2,\sqrt[3]{3}) : {\mathbb Q}(\sqrt[3]{3})] = 2$.
So that the degree is exactly
\[[{\mathbb Q}(\alpha) : {\mathbb Q}] = [{\mathbb Q}(\sqrt 2, \sqrt[3]{3}) : {\mathbb Q}(\sqrt[3]{3})] \times [ {\mathbb Q}(\sqrt[3]{3}) : {\mathbb Q}] = 2 \times 3 = 6 \]​
this means that the smallest possible degree is exactly 6.
Note: We have used that $ [ {\mathbb Q}(\sqrt[3]{3}) : {\mathbb Q}] = 3$ and $ [ {\mathbb Q}(\sqrt{2}) : {\mathbb Q}] = 2$. These follow from the fact that $x^3 - 3$ and $x^2 - 2$ have not roots in $\mathbb Q$, and so they are irreducible over $\mathbb Q$ (since their degree is $\leq 3$).
To show another approach, one can also find the minimal polynomial by using Galois Theory (plus using what we saw on the previous post here).
Indeed, remember ${\mathbb Q}(\alpha) = {\mathbb Q}(\sqrt 2, \sqrt[3]{3})$. And let $F = {\mathbb Q}(\sqrt 2, \sqrt[3]{3}, e^{2\pi i / 3})$. Note that $F/ {\mathbb Q}$ is a Galois extension, since it is the splitting field of $q(x) :=(x^2 - 2)\cdot (x^3 - 3)\in {\mathbb Q}[x]$
It follows now, since the extension $F/{\mathbb Q}$ is Galois, that the minimal polynomial $p(x) \in {\mathbb Q}[x]$ for $\alpha$ is the product \[p(x) = \prod_{a \in S} (x - a) \]
where $S = \{ \sigma (\alpha) : \sigma \in {\text{Gal}} \left(F / {\mathbb Q}\right)\}$, the set of the Galois conjugates of $\alpha$.
But what are the elements of $ {\text{Gal}} \left(F / {\mathbb Q}\right)$ ? Indeed, by the Fundamental Theorem of Galois Theory we have
\[ | {\text{Gal}} \left(F / {\mathbb Q}\right) | = [F : {\mathbb Q}] = 12\]
(the final part can be proved by using $6 = [{\mathbb Q}(\sqrt 2, \sqrt[3]{3}) : {\mathbb Q}]$, and noticing that $e^{2\pi i / 3}$ is a root of $x^2+x+1$ which doesn't have real roots, ando so has no roots in ${\mathbb Q}(\sqrt 2, \sqrt[3]{3}) \subseteq {\mathbb R}$).
Note that if $\sigma \in {\text{Gal}} \left(F / {\mathbb Q}\right)$, then $\sigma$ takes roots of $x^2 - 2$ to roots of $x^2 - 2$, and roots of $x^3 - 3$ to roots of $x^3 - 3$. Hence $\sigma (\sqrt 2) \in \{ \sqrt 2 , -\sqrt 2\}$, and $\sigma (\sqrt[3]{3}) \in \{\sqrt[3]{3}, \sqrt[3]{3}e^{2\pi i / 3},\sqrt[3]{3}e^{4\pi i / 3}\}$. Similarly, we note that $\sigma(e^{2\pi i / 3}) \in \{e^{2\pi i / 3},e^{4\pi i / 3}\}$ too, since it takes roots of $x^2+x+1$ to roots of $x^2+x+1$.
Since there are exactly twelve elements in the Galois group, this means that every choice for $\sigma(\sqrt 2)$, $\sigma(\sqrt[3]{3})$ and $\sigma(e^{2\pi i / 3})$ (by picking from the previous sets), the images of the generators, gives rise to an element of the Galois group. And conversly, this determines all of the elements of the Galois group.
Now it is easily checked then, that if we let $\omega = e^{2\pi i / 3}$ we have \[S = \{\sqrt 2 + \omega^0 \sqrt[3]{3}, \sqrt 2 + \omega \sqrt[3]{3}, \sqrt 2 + \omega^2 \sqrt[3]{3}, -\sqrt 2 + \omega^0 \sqrt[3]{3}, - \sqrt 2 + \omega^1 \sqrt[3]{3}, - \sqrt 2 + \omega^2 \sqrt[3]{3} \}\]
and now $p(x)$ is the product above :
\[p(x) = \prod_{j=0}^1 \prod_{k=0}^2 \left(x - (-1)^j \sqrt 2 - \omega^k \sqrt[3]{3} \right) \]
here, after doing operations for a while, we get
\[p(x) = x^6-6x^4-6x^3+12x^2-36x+1\]
as Opalg found earlier.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
