Find acceleration of a Block within a simply pulley system.
The discussion focuses on calculating the acceleration of block B in a pulley system where block B has twice the mass of block A. The initial approach involves using torque and moment of inertia equations, but it is pointed out that the assumptions made about tension forces are incorrect due to the system's acceleration. Participants emphasize the necessity of drawing free body diagrams for each block and the pulley to apply Newton's laws effectively. An alternative method suggested is to use energy conservation principles to find the acceleration. The correct approach is crucial for accurately determining the acceleration of block B.
cocoon
The figure shows two blocks suspended by a cord over a pulley. The mass of black B is twice the mass of black A, m_b = 2m_a = 2m. The mass of the pulley is equal to the mass of black A, m_p = m_a = m, the radius of the pulley is R. The blocks are let free to move and the cord moves on the pulley without slipping or stretching. There is no friction in the pulley axle, and the cords are massless. The rotational inertia of the pulley is \frac{m_pR^2}{2} about a perpendicular axis through the center. Find the magnitude of acceleration of the block B. Express your results in the simplest possible form in terms of any or all the following: m, g, R, and universal physical or mathematical constants.
F_G = m * g (force of gravity equals mass times gravitational acceleration)
\tau_net = I * \alpha (torque equals moment of inertia times angular acceleration)
\tau_{net} = I * \alpha = \frac{m * R^2}{2} * \alpha = \frac{m * R^3}{2} * a
furthermore,
\tau_{net} = F_{G on B} * R + F_{G on A} * R = 2 * m * g * R - m * g * R = m * g * R
so,
m * g * R = \frac{m * R^3}{2} * a
which leads to the answer:
a = \frac{2 * g}{R^2} m/s^2
Is this correct? Is there an easier way?
bump... picture of problem lol
http://img340.imageshack.us/img340/690/18485819.jpg
oops, slight error in your equation there a = \alpha R, so \tau = MRa/2
furthermore,
no, that's not right, you've assumed the respective tension forces are equal to the respective weights, but the system is accelerating, so the tensions cannot equal the weights
No, this is incorrect, you need to write 3 equations with 3 unknowns, T_A, T_B, and a, so draw Free Body diagrams (FBD's ) of each block and the pulley to solve for them... separte FBD's and application of Newton's laws to each are essential in these type problems. Trying to take shortcuts often results in incorerct methods and solutions.
this accn.. u solved is for t he pulley not for the block B
so use the principle of energy conversion to solve the problem then it will give the acceleration for block B..
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
