Find all the solutions of the equation
  • MHB
  • Thread starter mathmari
In summary, the conversation discusses finding all solutions of the equation $3^x+4^x=5^x$, with one solution being $x=2$. The process involves rewriting the equation and analyzing its derivative. It is determined that the derivative is always negative, indicating only one solution. To find the solution, one may use basic Pythagorean Triples.
mathmari
MHB
5,049
Hey! :eek:
I have to find all the solutions of the equation
$$3^x+4^x=5^x$$
I have done the following:
$$3^x+4^x=5^x \Rightarrow (\frac{3}{5})^x+(\frac{4}{5})^x=1$$
$$f(x)=(\frac{3}{5})^x+(\frac{4}{5})^2-1 \Rightarrow f'(x)=(\frac{3}{5})^x \ln{(\frac{3}{5})}+(\frac{4}{5})^2 \ln{(\frac{4}{5})}$$
Is it true that $f'(x)<0, \forall x \in \mathbb{R}$?? (Wondering)
If so, we would know that $f(x)$ has at most one solution.
How could I continue?? (Wondering)
mathmari said:
Hey! :eek:
$$3^x+4^x=5^x$$
$$3^x+4^x=5^x \Rightarrow (\frac{3}{5})^x+(\frac{4}{5})^2=1$$
Your idea is good but the correct procedure is to write...
$\displaystyle f(x) = (\frac{3}{5})^{x} + (\frac{4}{5})^{x} = 1\ (1)$
Because $\displaystyle f^{\ '} (x) < 0$ for all x , the equation has only one solution and it is easy o see that this solution is x=2...Kind regards
$\chi$ $\sigma$
$\chi$ $\sigma$
Do we know that $\displaystyle f^{\ '} (x) < 0$ for all x, because of the fact the $\ln{y}$ is negative in this case, and $y^x$>0, $y=\frac{3}{5},\frac{4}{5}$? (Wondering)
$\displaystyle \begin{align*} f(x) &= \left( \frac{3}{5} \right) ^x + \left( \frac{4}{5} \right) ^x - 1 \\ \\ f'(x) &= \left( \frac{3}{5} \right) ^x \ln{ \left( \frac{3}{5} \right) } + \left( \frac{4}{5} \right) ^x \ln{ \left( \frac{4}{5} \right) } \end{align*}$
Since $\displaystyle \begin{align*} \left( \frac{3}{5} \right) ^x \end{align*}$ and $\displaystyle \begin{align*} \left( \frac{4}{5} \right) ^x \end{align*}$ are both always positive, and $\displaystyle \begin{align*} \ln{ \left( \frac{3}{5} \right) } \end{align*}$ and $\displaystyle \begin{align*} \ln{ \left( \frac{4}{5} \right) } \end{align*}$ are both negative, we can conclude that the derivative is always negative.
Is...
$\displaystyle f(x) = e^{x\ \ln \frac{3}{5}} + e^{x\ \ln \frac{4}{5}} \implies f^{\ '} (x) = \ln \frac{3}{5}\ e^{x\ \ln \frac{3}{5}} + \ln \frac{4}{5}\ e^{x\ \ln \frac{4}{5}}\ (1)$
... and because $\displaystyle \ln \frac{3}{5}$ and $\displaystyle \ln \frac{4}{5}$ are both negative, the $\displaystyle f^{\ '} (x)$ is also negative...
Kind regards$\chi$ $\sigma$
chisigma said:
Is...
Great! Thank you both! (Happy)
To find that $x=2$ is the solution, is there a method? Or do we have to check diverses $x$ and then we see that $x=2$ satisfies the relation?
I can't think of a method to solve this type of equation analytically. But you should know some basic Pythagorean Triples...
Ok...Thanks! (Smile)
FAQ: Find all the solutions of the equation
What does it mean to "find all the solutions" of an equation?
Finding all the solutions of an equation means identifying all possible values for the variable(s) that satisfy the equation and make it true. This typically involves solving for the variable(s) and checking that the resulting value(s) work in the original equation.
How do you find all the solutions of a simple linear equation?
To find all the solutions of a simple linear equation, you can use basic algebraic techniques such as isolating the variable, combining like terms, and simplifying both sides of the equation. Then, you can check your solution(s) by plugging in the variable(s) and seeing if the equation is balanced.
Can an equation have more than one solution?
Yes, an equation can have more than one solution. This is especially common in quadratic equations, which can have two solutions, or cubic equations, which can have three solutions. In general, an equation can have as many solutions as the degree of the equation.
How do you know when you have found all the solutions of an equation?
You know you have found all the solutions of an equation when you have exhausted all possible values for the variable(s) and checked that each value satisfies the equation. If there are any remaining values that work, then you have not found all the solutions.
Are there any equations that have infinite solutions?
Yes, there are some equations that have infinite solutions. An example of this is a linear equation with two variables, such as y = 2x. In this case, any value of x can be paired with an appropriate value of y to satisfy the equation, resulting in an infinite number of solutions.
