MHB Find angle in radians of tractor wheel going 22 mph in 12 s
To find the angle in radians for a tractor wheel moving at 22 mph over 12 seconds, the discussion emphasizes using angular equations instead of linear ones. The formula v = rω is highlighted, where ω (angular velocity) is calculated by converting the linear speed to radians per second. The angle θ is then determined using the equation θ = ωt. The importance of unit conversions is also noted to ensure accuracy in calculations. This approach provides a systematic method for solving the problem.
karush
MHB
the calculation is mine however, if ans is correct not sure what the conventional way would to set this up?
Mathematics news on Phys.org
I typically would include the actual formulas you are using. I also tend to use the angular equations rather than trying to use the linear ones. For example: [math]v = r \omega[/math], so [math]\omega = \frac{v}{r}[/math] (And at this step you would do your unit conversions.)
Then you simply have [math]\theta = \omega t[/math].
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
