MHB Find Area of A Rectangle With Shortcut
  • Thread starter Thread starter susanto3311
    Area Rectangle
To find the area of a rectangle with a perimeter of 72 cm, additional information about the rectangle's dimensions is required, as multiple rectangles can share the same perimeter. By defining the height as a variable, the base can be expressed as the difference from half the perimeter, leading to the area formula A = (36 - h)h. The maximum area occurs when the rectangle is a square, yielding an upper limit of 324 cm². The semi-perimeter of 36 cm is crucial for determining the relationship between the base and height. Understanding these concepts allows for a straightforward calculation of the area based on the chosen dimensions.
susanto3311
hi all...
how do you find area of a rectangle, if its perimeter of a rectangle is = 72 cm?
i mean how to easy find it without hard work.
do you have a formula or just tricks similar like..
http://calculus-geometry.hubpages.com/hub/How-to-Find-the-Area-Perimeter-and-Diagonal-of-a-Rectangle
thanks in advance...
susanto
Mathematics news on Phys.org
For a given perimeter, there are an infinite number of rectangles that will have that perimeter. We need more information about the rectangle.
if perimeter of a rectangle is = 72 cm, counting area of a rectangle =...
i need simple formula to calculate it.
possible?
Well, suppose we let the height $0<h<36$ be a free variable, then the base $b$ is $b=36-h$. Thus the area $A$ is:
$$A=bh=(36-h)h$$
Thus we find:
$$0<A\le324$$
The sum of the base and the height must be equal to the semi-perimeter, which is 36...half of 72. And the maximum area comes from the base and height being equal. So the upper bound is $18^2=324$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
