Find Center of Gravity Distances for Cut Discs
The discussion focuses on calculating the distance between the centers of gravity of a uniform disc before and after a smaller disc is cut from it. The mass of the larger disc is determined to be 4π, while the mass of the cut-out disc is π. Using the formula for center of gravity, the calculated distance between the two centers is 0.333m. Participants express uncertainty about the accuracy of this result, with one suggesting that the distance might actually be closer to 0.5m. Overall, the conversation emphasizes the importance of correctly applying principles of mass proportionality and geometry in solving the problem.
crossfacer
A unifrom disc A of radius 2m is cut as shown in the image. The cut out is also a disc of radius 1m. Find the distance of the two center of gravity before and after the paper disc is cut.
http://crossfacer.com/circle.jpg
x=m1x1/M+m2x2/M+...
Mass of the disc is proportional to its area.
so mass of disc A=2^2pi=4pi units
mass of disc being cut out=1^2pi=pi units
Let x be the distance between the two centers of gravity.
(4pi-pi)(2-x)=(4pi)(2)-(2+1)(pi)
x=0.333m
This question is quite difficult for me. I don't have much confidence on my answer.:-p May anyone try it?:smile:
Your answer looks correct in my book.
You assume the homogeneity of the disc, and thus mass is proportional to the area. You know that together, they produce a center of gravity balanced at the center of disc A, and your equations reflect that.
I feel like my answer is not correct:frown:. I guess x should be about 0.5.
well to check maybe you could use same methods with your new result and cut out identical hole in left half. I think it will end up in the middle again.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
