Find Critical Points of Hessian Matrix
azatkgz
Please,check my solution.
Find critical points of the function f(x,y,z)=x^3+y^2+z^2+12xy+2z
and determine their types (degenerate or non-degenerate, Morse index for non-
degenerate).
Attempt
\frac{df}{dx}=3x^2+12y=0
\frac{df}{dy}=2y+12x=0
\frac{df}{dz}=2z+2=0
Critical points are at
x=24 y=-144 z=-1
x=0 y=0 z=-1
H(f)=\left|\begin{array}{l[cr]}6x&12&0\\12&2&0\\0&0&2\end{array}\right|
for x=24
det\left|\begin{array}{l[cr]}144&12&0\\12&2&0\\0&0&2\end{array}\right|=288 non-degenerate
for x=0
det\left|\begin{array}{l[cr]}0&12&0\\12&2&0\\0&0&2\end{array}\right|=-288 non-degenerate
degenerate).
Attempt
x=24 y=-144 z=-1
x=0 y=0 z=-1
for x=24
for x=0
keep going... are they minimum, maximum.. saddle points??
Morse index
for (0,0,-1)
det\left|\begin{array}{l[cr]}-\lambda &12&0\\12&2-\lambda &0\\0&0&2-\lambda\end{array}}\right|=0
(2-\lambda )(-\lambda(2-\lambda)-144)=0
\lambda_1=2,\lambda_2=1-\sqrt{145},\lambda_3=1+\sqrt{145}
for (24,-144,-1)
det\left|\begin{array}{l[cr]}144-\lambda &12&0\\12&2-\lambda &0\\0&0&2-\lambda\end{array}}\right|=0
(2-\lambda )((144-\lambda)(2-\lambda)-144)=0
\lambda_1=2,\lambda_2=73-\sqrt{5185},\lambda_3=73+\sqrt{5185}
Is it right?What we can say about maximum,minimum and saddle points?
azatkgz said:
Morse index
for (0,0,-1)
for (24,-144,-1)
i didnt check you're calculus, but find what the sign of eigenvalues mean and you'll get you're answer.
bye
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
