Find current using KVL (with dependent source)
The discussion focuses on applying Kirchhoff's Voltage Law (KVL) to find the current using dependent sources in a circuit. The user initially calculated the current Ix as 2 mA but expected it to be 1.5 mA, prompting a request for help in identifying the error. After reviewing the equations, it was determined that the mistake was in not properly accounting for the unit conversion of Ix from mA. The corrected equations were confirmed, leading to the resolution of the problem. This highlights the importance of unit consistency in circuit analysis.
iharuyuki
V = IR
Kirchoff's Voltage Law
[/B]
Top loop - a
Bottom right - b
Bottom left - c
Ix = x
KVL:
top: a(6000) + (a-b)(2000) + 5x - 10=0
bottom right: -5x + (b-a)(2000) + b(3000) + (b-c)(4000) = 0
bottom left : 10 + (c-b)(4000) + c(2000) = 0
x = -c
x comes out to 2 mA when it should be 1.5. Where did I make a mistake?
Thank you very much.
How did you account for the given detail that ##I_x## is in mA?
got it! That was the error. The proper equations were this:
x/1000 = -c
Thank you very much!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
