MHB Find Difference Quotient & Evaluate/Approximate Limits
To evaluate or approximate limits after finding a difference quotient, algebraic manipulation is often necessary, particularly to cancel out the Δx in the denominator as it approaches zero. The process involves several steps: first, find f(x+h) by substituting x with x+h, then subtract f(x) and simplify. After that, divide by h and factor to reduce the expression. Finally, take the limit as h approaches zero to find the derivative. The example provided demonstrates that the derivative of f(x) = 4 - 2x - x² is f'(x) = -2 - 2x.
Jaclbl
I understand how to find a difference quotient, but afterwards it asks me to then evaluate or approximate each limit, is that just by plugging in the given limit or is there another step?
Mathematics news on Phys.org
Hi Jaclbl,
Welcome to MHB! :)
It would be much better to look at a real problem I think, but in general these limits usually require a cancellation because in the denominator you have a $\Delta x$ and the limit is $\Delta x \rightarrow 0$, so some algebraic manipulation is required to hopefully cancel something out.
Ah, I don't want to do the exact problem, because it is for homework, but I'll send one of the ones that is like it, for an example.
lim F(x+h)-f(x)
h-0 h
f(x) = 4 - 2x -x2
lim F(x+h)-f(x)
h-0 h
f(x) = 4 - 2x -x2
Ok, sounds good. What are $f(x+h)$ and $f(x)$ for this problem?
Hello, Jaclbl!
f(x) \:=\:4-2x-x^2
Find: \;\lim_{h\to0}\frac{f(x+h) - f(x)}{h}
I have taught my students to make four steps.
(1) Find f(x+h); replace x with x+h, and simplify.
(2) f(x+h) - f(x): subtract f(x), and simplify.
(3) \frac{f(x+h)-f(x)}{h}: divide by h . . . factor and reduce.
(4) \lim_{h\to0}\frac{f(x+h)-f(x)}{h}: take limit as h\to 0.We are given: \:f(x) \:=\:4 - 2x - x^2
(1)\;f(x+h) \:=\:4-2(x+h) - (x+h)^2 \:=\:4 - 2x - 2h - x^- 2xh - h^2
(2)\;f(x+h)- f(x)
. . . =\: (4-2x-2h - x^2 - 2xh - h^2)-(4-2x-x^2) \:=\:\text{-}2h -2xh - h^2
(3)\;\frac{f(x+h)-f(x)}{h} \;=\;\frac{\text{-}2h-2xh-h^2}{h} \;=\;\frac{h(\text{-}2-2x-h)}{h} \;=\;\text{-}2-2x-h
(4)\;\lim_{h\to0}\frac{f(x+h)-f(x)}{h} \;=\;\lim_{h\to0}(\text{-}2-2x-h) \;=\;\text{-}2-2xTherefore, the derivative of f(x)\:=\:4-2x-x^2 is: \;f'(x) \:=\:-2-2x
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
