MHB Find force with Young's modulus
To calculate the force applied by a piano tuner to stretch a steel wire, Young's modulus (E) for steel is given as 20.0 x 10^10 Pa. The original length (L_0) of the wire is 1.35 m, and the change in length (ΔL) is 8.5 mm, converted to meters as 0.0085 m. The radius (r) of the wire is 0.425 mm, or 4.25 x 10^-4 m. The formula for force (F) is F = E * π * r^2 * ΔL / L_0, which incorporates these values to determine the force in Newtons. This calculation is essential for understanding the mechanical properties of materials under stress.
cbarker1
MHB
Q: Calculate the force (in N) a piano tuner applies to stretch a steel piano wire 8.50 mm, if the wire is originally 0.850 mm in diameter and 1.35 m long. (Young's modulus for steel is 20.0 1010 Pa.)
Work F=Y*A*change in L/L_0
I have no idea what is L_0 and L_f? Please help me.
Mathematics news on Phys.org
$L = 1.35 \, m$
$\Delta L = 8.5 \times 10^{-3} \, m$
$r = 4.25 \times 10^{-4} \, m$
$E=2.0 \times 10^{11} \, N/m^2$$F = \dfrac{E \cdot \pi r^2 \cdot \Delta L}{L}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
