MHB Find General Form of Z & T: Newton's Law of Cooling
Recce
A cup of tea is removed from the fridge and left on a desk. The temperature of the room is constantly E and T(t) represents the temperature of the tea after t minutes.
dT/dt = K(E-T) Z(t) = E-T(t)
How do I find the general form of Z and T?
Hello ystyegn! (Wave)
Newton's law of Cooling states that the time rate of change of the temperature $T$ of an object is proportional to the difference between the ambient temperature $M$ and the temperature of the object. Stated mathematically, this is:
$$\frac{dT}{dt}=k(M-T)$$ where $$T(0)=T_0,\,0<k\in\mathbb{R}$$.
The ODE is separable and may be written:
$$\frac{1}{T-M}\,dT=-k\,dt$$
Integrating, using the boundaries, and changing dummy variables of integration, we find:
$$\int_{T_0}^{T(t)}\frac{1}{u-M}\,du=-k\int_0^t \,dv$$
Can you proceed by applying the FTOC?
Hey,
Is there a way to do this question without using integral because I haven't learn any integral yet? I don't know what this equation means $$\int_{T_0}^{T(t)}\frac{1}{u-M}\,du=-k\int_0^t \,dv$$
Well, we could write the given ODE in the form:
$$\d{T}{t}+kT=kM$$
Then, if we observe that multiplying though by $e^{kt}$:
$$e^{kt}\d{T}{t}+ke^{kt}T=kMe^{kt}$$
We now have on the left:
$$\frac{d}{dt}\left(e^{kt}T\right)=e^{kt}\d{T}{t}+ke^{kt}T$$
And so we may now write:
$$\frac{d}{dt}\left(e^{kt}T\right)=kMe^{kt}$$
Let's stop and think about what we have now...we have the derivative of a function of $t$ being equal to a constant times an exponential function...so let's write:
$$\frac{d}{dt}f(t)=c_1e^{kt}$$
If the derivative of a function is a constant times an exponential, then what must the function be?
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
