Tanya Sharma
- 1,541
- 135
Correct...So forget energy conservation :)
Tanya Sharma said:Correct...So forget energy conservation :)
Tanya Sharma said:We need another equation apart from the last four equations by Chet in post#23
Pranav-Arora said:Are you talking about this?
https://www.physicsforums.com/showpost.php?p=4689443&postcount=15
I think we don't need the equations from #23, page 1 of this thread has it all. Chestermiller derived ##\omega^2## and ##\alpha## as a function of ##\theta## in post #15 and I suppose that is sufficient. Next step is to apply Newton's second law.
Tanya Sharma said:I may be wrong but I think the equation in post#15 is incorrect .You cannot write torque equation about the hinge .
In this problem it has to be written about the COM.
Except we know what that work is as it is explicitly given in the problem. In this case the work done is only in one direction and if we are only interested in the rotational energy then we can solve directly for ω without doing any integration.Tanya Sharma said:Correct...So forget energy conservation :)
Tanya Sharma said:Congrats for getting the correct answer .Quite a difficult problem .
Could you share exactly what equations you used and what is the correct answer ?
utkarshakash said:OK here's what I did:
Since Chet already figured out ω I used that to put it in this equation
R_x - mg = m \omega ^2 l
Not true. You can take any frame of reference you want. Taking moments about the hinge simplifies the problem.Tanya Sharma said:I may be wrong but I think the equation in post#15 is incorrect .You cannot write torque equation about the hinge .
The pseudo forces or inertial forces are there regardless of what reference frame you pick. So it's wrong to say you have to take it only at the center of mass. I think using conservation of energy is another way to do it but doesn't involve solving a differential equation.Chestermiller said:So it looks like Tanya was right about the need to take moments about the center of mass, and utkarshakash and Pranav-Arora were right about the need to include the pseudo reaction force if you take moments about the hinge.
Pranav-Arora said:Okay, I have tried something which gives the correct answer of ##\sqrt{257}mg/4##.
Move to the frame accelerating with an acceleration a=g. This results in a pseudo force of mg acting on the rod towards left.
Doing moment balance when the rod is at an angle ##\theta##, gives:
$$ mg\frac{l}{2}\sin\theta+mg\frac{l}{2}\cos\theta=\frac{ml^2}{3}\alpha $$
Rewriting alpha as ##\dfrac{1}{2}\dfrac{d\omega^2}{d\theta}## and simplifying gives:
$$\frac{d\omega^2}{d\theta}=\frac{3g}{l}(\sin\theta+\cos\theta)$$
Solving the D.E gives:
$$\omega^2=\frac{3g}{l}(1-\cos\theta+\sin\theta)$$
At ##\theta=\pi/2##, ##\omega^2=6g/l##. From Newton's second law:
$$R_x-mg=m\omega^2\frac{l}{2} \Rightarrow R_x=4mg$$
This is the same value which utkarshakash posted and I am inclined to think that what I have done above makes more sense because I wrote ##R_x-mg=m\omega^2\frac{l}{2}## instead of ##R_x-mg=m\omega^2l##. But then Chet said that we don't take into account the pseudo forces when taking moments.
EDIT: If I work in this accelerating frame, I can get the value of ##\omega^2## directly from energy conservation.
$$\frac{mgl}{2}+\frac{mal}{2}=mgl=\frac{1}{2}\frac{ml^2}{3}\omega^2$$
$$\Rightarrow \omega^2=\frac{6g}{l}$$
If you don't want to have to include a pseudo force, (and you are using an inertial frame of reference) then you have to take moments about the center of mass. Tanya already pointed out the error of not taking moments around the center of mass, and I confirmed Tanya's assertion in my most recent post.paisiello2 said:The pseudo forces or inertial forces are there regardless of what reference frame you pick. So it's wrong to say you have to take it only at the center of mass.
So far you've said that several times, but we still haven't seen your demonstration of how it can be done.I think using conservation of energy is another way to do it but doesn't involve solving a differential equation.
That's not what I said. What I said was the inertia forces are there regardless of what reference frame you choose. So Tanya made an erroneous statement.Chestermiller said:If you don't want to have to include a pseudo force, (and you are using an inertial frame of reference) then you have to take moments about the center of mass. Tanya already pointed out the error of not taking moments around the center of mass, and I confirmed Tanya's assertion in my most recent post.
utkarshakash said:But why should we use l/2 here? Since the rod rotates about the hinge, shouldn't it be l? It'd be nice if you could explain me.
paisiello2 said:That's not what I said. What I said was the inertia forces are there regardless of what reference frame you choose. So Tanya made an erroneius statement.
Chestermiller said:OK. I'm going to do this a another way, by taking moments about the center of mass. This should focus on Tanya's concern about taking moments about the hinge, and should also address utkarshakash and Pranav-Arora's contention that the pseudo force needs to be included if we take moments about the hinge. Taking moments about the center of mass gives:
R_x\frac{l}{2}\cosθ+R_y\frac{l}{2}\sinθ=\left(m\frac{l^2}{12}\right)<br /> \frac{d^2θ}{dt^2}
Note that, on the right hand side of this equation, I've used the moment of inertia about the center of mass. Now, from the force balance and the kinematics,
R_x=m\left(g-\frac{l}{2}\cosθ\frac{d^2θ}{dt^2}+<br /> \frac{l}{2}\sinθ\left(\frac{dθ}{dt}\right)^2\right)
R_y=mg-m\left(\frac{l}{2}\sinθ\frac{d^2θ}{dt^2}+\frac{l}{2}\cosθ\left(\frac{dθ}{dt}\right)^2\right)
Now if we substitute these equations for the reaction forces into the moment balance equation and combine terms, we obtain:
mg\frac{l}{2}\cosθ+mg\frac{l}{2}\sinθ=m\left(\frac{l^2}{3}\right)\frac{d^2θ}{dt^2}
This is identical to Pranav-Arora's equation in the previous post. So it looks like Tanya was right about the need to take moments about the center of mass, and utkarshakash and Pranav-Arora were right about the need to include the pseudo reaction force if you take moments about the hinge.
Chet
Pranav-Arora said:Lets consider a rod of mass m rotating with a constant angular velocity ##\omega##. In the rotating frame, a centrifugal force acts on it. Consider a small length (##dx##) of rod at a distance x from the hinge. The centrifugal force on it is given by ##(m/l)\omega^2x\,dx##. Integrating to calculate the net centrifugal force gives ##m\omega^2l/2## which is the result I used in the problem.
I hope that helps.
See what for myself? That I can't take moments about any point I want?Pranav-Arora said:Hi paisiello2!
How about writing down a few equations and see for yourself? ;)
utkarshakash said:Thanks!
I have one more doubt. Do we associate potential energy corresponding to a pseudo force just like you did in energy conservation?
Pranav-Arora said:I did not associate any potential energy to the pseduo force. I simply wrote the work done by the pseudo force. Remember, the work done is force times the displacement in the direction of force. The pseudo force is mg and the displacement in its direction is l/2.
paisiello2 said:That's not what I said. What I said was the inertia forces are there regardless of what reference frame you choose. So Tanya made an erroneous statement.
I believe Pranav-Arora showed this already in a post previous to yours. This contradicts what Tanya said about "forgetting conservation of energy" and it is a much simpler way to solve the problem.Chestermiller said:So far you've said that several times, but we still haven't seen your demonstration of how it can be done.
Of course, in the accelerated frame, doing it using energy conservation is no problem because there the pseudo force becomes an actual body force with a horizontal "graviational" potential (as reckoned by observers in the accelerated frame.)
paisiello2 said:I believe Pranav-Arora showed this already in a post previous to yours. This contradicts what Tanya said about "forgetting conservation of energy" and it is a much simpler way to solve the problem.
The inertial forces are still there, however:Chestermiller said:...we are supposed to include only moments resulting from body forces and contact forces, not ma (through the center of mass) and not pseudo forces.
I disagree in the statement that you have to do the moment balance about the center of mass. You got the wrong answer because you didn't include the inertial forces which I claim are there regardless of where you take the moment axis.Chestermiller said:...if the center of mass of the rigid body is accelerating relative to our frame of reference, then, in order to get the correct answer, we needed to do the moment balance about the center of mass. Otherwise, we would get the wrong answer (as I did in my post #15, when I failed to honor this rule).
I think this is just trivial statics but I agree of course.Chestermiller said:...if the center of mass of our rigid body is not accelerating relative to our inertial frame of reference, then we can take moments about any convenient axis (and get the right answer).
Here is where you sort of confuse me because I think you are contradicting what you said in the second quote above:Chestermiller said:Moment balances can also, of course, be done relative to a non-rotating frame of reference that is at rest relative to the center of mass of the body, even if the center of mass is accelerating relative to inertial frames of reference. In this type of situation, the pseudo force reckoned from an inertial frame of reference becomes a real body force as reckoned from the accelerating frame of reference. So, accordingly, this real body force must be included in the moment balance for the accelerating frame of reference. Since, as reckoned from the accelerating frame of reference, the center of mass is at rest, the moment balance can be taken about any convenient axis (again, provided the body force is included).
But she didn't say "in the lab or inertial frame". She said just forget about it. So her blanket statement is wrong.Pranav-Arora said:Hey paisiello! :)
Tanya is correct. Conservation of energy won't work in the lab or inertial frame as we don't know the work done by external force in that frame. But when we move to the accelerated frame, as Chet said, we have got a actual body force so there is no problem in using the conservation of energy.
I hope that addresses your doubt. ;)
paisiello2 said:Hi Chet:
Thanks very much for your civility in your post. I will do the same in my response and maybe we can both learn something in the discussion of our different view points. I certainly admit I might be wrong here for some reason that I cannot see but maybe you might admit the same.
∑F = ma
→ ∑F - ma = 0
You can interpret the ma term as the inertial force acting opposite to the other body forces. If you take moments about the center of mass then of course the lever arm is zero and so the moments are zero but the inertial forces are still there.
Apparently, there is no one right way of doing the moment balance. If you include the pseudo force, then you can take moments about any convenient axis, and, if you don't include the pseudo force, you must take moments about the center of mass (unless ma = 0). Most of us learned to do it without the pseudo force, and are unaccustomed to (and uncomfortable with) using the pseudo force approach.I disagree in the statement that you have to do the moment balance about the center of mass. You got the wrong answer because you didn't include the inertial forces which I claim are there regardless of where you take the moment axis.
2) Now you are saying you can take moments about any axis after all, but you qualify it by saying it has to be a non-rotating inertial frame of reference.
