Find Integral: $\int_{a}^{\infty}e^{-st}t^{n}dt$
  • MHB
  • Thread starter evinda
  • Tags
    Integral
In summary: Incomplete Gamma function is difficult to deal with. as I said the easiest way is IBP. I am busy at the moment to derive a formula but for easiness try the following \int^{\infty}_a e^{-t} t^n \, dtIf you cannot derive a formula, I can do it... but it will take some time.
evinda
MHB
3,836
Hey! :)
Could you explain me how I can find the integral $\int_{a}^{\infty}e^{-st}t^{n}dt$?
You need to eliminate $t^n$ by multiple differentiation using integration by parts. Start by integrating $e^{-st}$ then differentiate $t^n$ and so one until $t^n$ vanishes.
But..isn't there also an other way?Because the value of n is not given.So,how can I know how many times I have to make integration by parts? :confused:
There surely are other ways. That thing there is related to incomplete gamma function, upto some constant factor.
It is like that,right? $\Gamma(p+1)=\int_{0}^{\infty}e^{-x}x^{p}dx$
How can I use this??
Yes , there are other ways. As Balarka said using Incomplete Gamma function. Since, you are most problably interested in elementary techniques this is the most standard way. Since n is a positive integer (it should be due to convergence issues), it decreases by one each time IBP is employed. You can then proceed by induction. Actually for the complete integral
\(\displaystyle \int^{\infty}_0 e^{-st}t^{n} \, dt=\frac{n!}{s^{n+1}}\)
The proof of this could be done using IBP or the Gamma function.
That is gamma function you are using there. See this. For integer arguments this is really equal to
$$\frac{n!}{s^{n+1}}$$
So,I can just say that the integral is equal to $L\{t^{n}\}$ ,right?
Yes, you can denote is as a Laplace transform instead, that is correct.
Well, if you are finding
\(\displaystyle \mathcal{L}(t^n) = \int^{\infty}_0 e^{-st}t^n \, dt= \frac{\Gamma(n+1)}{s^{n+1}}\)
But for
\(\displaystyle \int^{\infty}_a e^{-st}t^n\, dt = \frac{\Gamma(n+1,a)}{s^{n+1}}\)
But for
I haven't get taught the incomplete gamma function.Couldn't I just use the gamma function,or do I have to use the incomplete gamma function?? :confused:
I remember having read somewhere about inexpressibility of incomplete gamma in terms of gamma using complicated transcendence theory but I cannot recall it now, so don't rely on this post much. Z is the expert here.
That is correct, although it is nice to have a normal expression for it.
The standard (engineering) way to find Laplace transforms, is to look it up in a Table of Laplace transforms.
Here you can find that:
$$\mathcal L\{t^{n}\} = \frac{n!}{s^{n+1}}$$
As ZaidAlyafey suggested, the standard approach to calculate it yourself would be repeated application of the partial integration rule.
Or alternatively:
\begin{aligned}\frac{d^n}{ds^n} \int_0^\infty e^{-st}dt
&= \int_0^\infty \frac{d^n}{ds^n} e^{-st}dt \\
&= (-1)^n \int_0^\infty e^{-st}t^n dt \end{aligned}
Since we also have:
\begin{aligned} \frac{d^n}{ds^n} \int_0^\infty e^{-st}dt
&= \frac{d^n}{ds^n}\Big( \frac {-e^{-st}}{s}\Bigg|_0^\infty \Big) \\
&= \frac{d^n}{ds^n}\Big( \frac {1}{s} \Big) \\
&= (-1)^n \frac{n!}{s^{n+1}} \end{aligned}
It follows that:
$$\int_0^\infty e^{-st}t^n dt = \frac{n!}{s^{n+1}}$$
\(\displaystyle \int^{\infty}_a e^{-t} t^n \, dt\)
If you cannot derive a formula, I can do it later.
(Not really on-topic but : Shh! Don't disturb Z, he is trying to get his INC4 integration result right :p)
Or alternatively:
&= (-1)^n \int_0^\infty e^{-st}t^n dt \end{aligned} $$ ?
Since we also have:
&= \frac{d^n}{ds^n}\Big( \frac {-e^{-st}}{s} dt \Bigg|_0^\infty \Big) \\
It follows that:
Can I also applicate the partial integration rule at the integral $$\int_a^\infty e^{-st}t^n dt $$
Using partial integration, let's define:
$$I_n = \int_0^\infty e^{-st}t^n dt$$
Then we have with partial integration that:
\begin{array}{ccccc}
I_n &=& \int_0^\infty t^n d\Big(\frac{-e^{-st}}{s}\Big) \\
&=& t^n\frac{-e^{-st}}{s}\Bigg|_0^\infty &+& \int_0^\infty \frac{e^{-st}}{s}d(t^n) \\
&=& 0 &+& \frac n s \int_0^\infty e^{-st} t^{n-1}dt \\
&=& \frac n s I_{n-1} \end{array}
It follows that:
$$I_{n-1} = \frac {n-1} s I_{n-2}$$
$$I_{n-2} = \frac {n-2} s I_{n-3}$$
Substituting, we get that:
$$I_n = \underbrace{\frac n s \cdot \frac {n-1} s \cdot \frac {n-2} s \cdot ... \cdot \frac 1 s}_{n\text{ factors}} \cdot I_0 = \frac{n!}{s^n} \cdot I_0$$
For $I_0$ we have that:
$$I_0 = \int_0^\infty e^{-st} dt = \frac{-e^{-st}}{s}\Bigg|_0^\infty = \frac 1 s$$
So:
$$I_n = \frac {n!}{s^{s+1}}$$
It follows that:
So:
But,the interval is $[a,\infty]$ .Isn't there a difference?
Oops, I missed the $a$.
But... perhaps you can redo the calculation with an $a$ instead of a $0$?
Or alternatively, you can use the Laplace table and apply the result for a delayed nth power.
Will it be then,$$I_{n}=I_{0}\frac{n!}{s^{n}}+\frac{e^{-sa}(1-a^{n})}{(1-a)s} $$?Or am I wrong? :confused:
So...now,I made the calculations and I found that:
$$I_{n}=e^{-sa}\Sigma_{k=1}^{n}\frac{a^{n+1-k}n!}{s^{2k-1}(n-k+1)!}+\frac{n!}{s^{2n}}I_{0} \text{ ,where } I_{0}=\frac{e^{-sa}}{s}$$ .
But...how can I find this sum?? :eek:
Well, you are expected to have a finite sum. You don't need to evaluate it. Verify the result for chosen values of $(n,s,a)$.
Actually since we are working on Incomplete gamma function , we will not get a nice looking expression as for the gamma function. The gamma function goes like \(\displaystyle \frac{1}{n(n-1)(n-2) \cdots 1}=\frac{1}{n!}\)
But Incomplete gamma function as the name expresses doesn't work as nice. Actually we expect something close to the \(\displaystyle \sum {n \choose k } \). But I haven't yet verified your expression.
I have found the result,using partial integration.Do you think that it is wrong? :confused:
Try it for some values or post the full solution and I can check it for you. Remember that for $a \to 0 $ the result should converge to \(\displaystyle \mathcal{L}(t^n)\).
Is there not a way I could calculate the sum I found?? :confused:
evinda said:
Why should it converge to \(\displaystyle \mathcal{L}(t^n)\) for $a \to 0 $ ?
- - - Updated - - -
I get:
$$I_{n}=e^{-sa}\sum_{k=1}^{n}\frac{a^{n+1-k}n!}{s^{k+1}(n-k+1)!}+\frac{n!}{s^{n}}I_{0} \text{ ,where } I_{0}=\frac{e^{-sa}}{s}$$
To be honest, I don't know how to calculate the sum.
Now, to verify part of it.
We already know that with $a=0$ we should get $\mathcal L\{t^n\} = \frac{n!}{s^{n+1}}$.
For $a=0$ the summation in your expression is zero, leaving only the last part.
This is where you can see that your $s^{2n}$ should really be $s^n$.Alternatively, you can write that:
$$I_n = \mathcal L\{t^n u(t-a)\} = e^{-sa} \mathcal L\{(t+a)^n\}$$
where $u(t)$ is the unit step function (0 for a negative argument, 1 for a positive argument).
I like Serena said:
I get:
$$I_{n}=e^{-sa}\Sigma_{k=1}^{n}\frac{a^{n+1-k}n!}{s^{k+1}(n-k+1)!}+\frac{n!}{s^{n}}I_{0} \text{ ,where } I_{0}=\frac{e^{-sa}}{s}$$
Now, to verify it.
We already know that with $a=0$ we should get $\mathcal L(t^n) = \frac{n!}{s^{n+1}}$.
I found that $$I_{n}=\frac{e^{-sa}a^{n}}{s}+\frac{nI_{n-1}}{s^{2}}$$
$$\text{so, }I_{n-1}=\frac{e^{-sa}a^{n-1}}{s}+\frac{(n-1)I_{n-2}}{s^{2}}$$ ans so on.What have I done wrong??
I get:
$$I_{n}=\frac{e^{-sa}a^{n}}{s}+\frac{nI_{n-1}}{s}$$
I like Serena said:
I get:
Oh sorry!I accidentally wrote at one equation twice the $s$..
Now,I get $$I_{n}=e^{-sa}\Sigma_{k=1}^{n} \frac{a^{n+1-k}}{s^{k}}\frac{n!}{(n-k+1)!}+\frac{n!I_{0}}{s^{n}}$$ .
What have I done wrong now?? :confused:
- - - Updated - - -
And also...why do we know that with $a=0$ we should get $\mathcal L\{t^n\} = \frac{n!}{s^{n+1}}$ ?
  • #31
In retrospect I believe that is correct.
I had summed with different indices and I made a mistake when converting those.
- - - Updated - - -
Applying the definition of the Laplace transform we have:
$$\mathcal L\{t^n\} = \int_0^\infty e^{-st}t^n dt$$
This is your integral with $a=0$.
Additionally, in post http://mathhelpboards.com/differential-equations-17/find-integral-8382-2.html#post38771 and post http://mathhelpboards.com/differential-equations-17/find-integral-8382-2.html#post38777, I showed in different ways that it is equal to \(\displaystyle \frac{n!}{s^{n+1}}\).
  • #32
Great! :eek:
oh yes!Right!And to explain why it is right,can I just say that it is verified for $a=0$ ?
  • #33
evinda said:
Great! :eek:
To be honest, that is only very little verification, since it doesn't touch the sum-part of the expression.
For a proper verification, I think you should also verify it for say $a=1$ and $n=1$ and also for $a=2$ and $n=3$.
Easy enough to do with W|A.
  • #34
I checked it for the values $a=1$ and $n=1$ and $a=2$ and $n=3$,and the results were the same with the Laplace transform! :) So,do I have to write these two examples,for verification?
  • #35
Good! ;)
No need. It suffices that you are sure that your formula is correct.
You should write down the steps how you got to the formula though.
