Find interval and root of polynomial with absolute error less than 1/8
songoku
Find an interval of length ##\frac{1}{4}## which contains root of ##x^3+2x+1=0##. Then using that interval, give approximate value of the root with absolute error less than ##\frac{1}{8}##
Intermediate Value Theorem (IVT)
Limit (maybe)
By IVT and trial and error, I get the interval to be ##(-\frac{1}{2},-\frac{1}{4})##
I don't know how to do the next part.
Let the actual root of the polynomial be ##x_{0}## and the approximate value is ##p##, we have ##|p-x_{0}|<\frac{1}{8}##
I am not sure how to continue.
Thanks
https://www.wolframalpha.com/input?i=plot+y=x^3+2x+1&lang=en
f(x)=x^3+2x+1
Say [a,b] is the range we choose, linear line between, i.e.,
y-f(a)=\frac{f(b)-f(a)}{b-a}(x-a)
cross the x axis at
x=-\frac{(b-a)f(a)}{f(b)-f(a)}+a
This is a candidate of approximate solution which should be investigated to be within the cited error.
[EDIT]
f(a)<0, f(b)>0
If f(##\frac{a+b}{2}##)<0 we can halve the size of the section [##\frac{a+b}{2}##,b].
If f(##\frac{a+b}{2}##)>0 we can halve the size of the section [a,##\frac{a+b}{2}##].
Likes songoku and SammyS
f(x)=x^3+2x+1
cross the x axis at
[EDIT]
f(a)<0, f(b)>0
So the idea is to use linearization and then change the interval based on the value of ##x## obtained from linearization until the interval length is < ##\frac{1}{8}##?
Thanks
f(a)<0, f(b)>0
If f((a+b)/2)<0 we can halve the size of the section [(a+b)/2,b].
If f((a+b)/2)>0 we can halve the size of the section [a,(a+b)/2].
Please forget the part before [EDIT]. Bisection method https://en.wikipedia.org/wiki/Bisection_method applies here. We can get better convergence by Newton method.
Thank you very much for the help and explanation anuttarasammyak
