MHB Find k: 3x^2 + sqrt{2k}x + 6 = 0
  • Thread starter Thread starter mathdad
To find the value of k for the equation 3x^2 + sqrt{2k}x + 6 = 0 to have exactly one root, the discriminant must equal zero. This leads to the equation 2k - 72 = 0, resulting in k = 36. An alternative method confirms this by analyzing the vertex of the quadratic, showing that it also leads to the same conclusion. Thus, the required value of k is 36. The discussion effectively demonstrates the application of the discriminant in determining the conditions for a single root.
mathdad
Find the value of k such that the equation has exactly one root.
This question involves the discriminant, right?
b^2 - 4ac = 0
(sqrt{2k}^2 - 4(3)(6) = 0
2k - 72 = 0
2k = 72
k = 72/2
k = 36
Correct?
Mathematics news on Phys.org
b^2 - 4ac = 0
2k - 72 = 0
2k = 72
k = 72/2
k = 36
Correct?
Yes correct.
Alternatively,
$$3x^2+\sqrt{2k}x+6=0$$
$$3\left(x^2+\frac{\sqrt{2k}}{3}x\right)+6=0$$
$$3\left(x+\frac{\sqrt{2k}}{6}\right)^2+6-3\left(\frac{\sqrt{2k}}{6}\right)^2=0$$
If the equation has exactly one real root then the vertex "touches" (is tangent to) the $x$-axis, so
$$6-3\left(\frac{\sqrt{2k}}{6}\right)^2=0$$
$$6=3\left(\frac{\sqrt{2k}}{6}\right)^2$$
$$6=3\frac{2k}{36}$$
$$2=\frac{2k}{36}$$
$$72=2k$$
$$k=36$$
greg1313 said:
Alternatively,
$$2=\frac{2k}{36}$$
$$72=2k$$
$$k=36$$
Nicely done!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
