MHB Find Length of Side in Right Triangle w/ 45°, 90°, and 45° Angle
  • Thread starter Thread starter Monoxdifly
    Angle Triangle
In a right triangle ABC with a right angle at A and angle bisector BD, the lengths AB and BC are given as 12 cm and 15 cm, respectively. To find the length of segment AD, the Angle Bisector Theorem is applied, leading to the equation AD/12 = (9 - AD)/15. Solving this equation reveals that AD equals 6 cm. The discussion highlights the importance of understanding the Angle Bisector Theorem, especially for students who have not yet learned trigonometry. This approach provides a foundational method for solving problems involving right triangles and angle bisectors.
Monoxdifly
MHB
The triangle ABC is a right triangle with A as the right angle and BD is the bisector of angle B. If AB = 12 cm and BC = 15 cm, the length of AD is ...
A. 3 cm
B. 4 cm
C. 5 cm
D. 6 cm
It was a question for a 9th grader and the book hasn't covered trigonometry by name yet (As in, they don't know about the term sine, cosine, and tangent, but the books do explain the length ratio of triangle which has 45°-90°-45° angle or 30°-60°-90° angle. How to do it and explain it to them?
Mathematics news on Phys.org
Pythagoras $\implies AC = 9$
using the ...
$\dfrac{AD}{AB} = \dfrac{CD}{BC}$
$\dfrac{AD}{12} = \dfrac{9-AD}{15}$
solve for $AD$
Never knew that this theorem exists. Gotta learn how it was derived from now.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
