Find Limit of F(x) at x=1: 2x^2, 3, x+
  • Thread starter Thread starter bard
    Limit
To find the limit of F(x) as x approaches 1, it is essential to evaluate the values from both sides. The left-hand limit as x approaches 1 is 2, and the right-hand limit is also 2. Since both limits are equal, the overall limit exists and is equal to 2. The value of the function at x=1, which is 3, does not affect the limit calculation. Therefore, the limit of F(x) as x approaches 1 is 2.
bard
F(x)= 2x^2, x<1
3, X=1
X+, x>1
Find
lim(x-->1) f(X)
f(1)=
not exactly sure how to do this. would not f(1) be just 3, since it is defined as that in the function. I am not sure about how to take that limit.
Thanks
When it comes to the limit of a function at x=a, the value of the function at a is irrelevant. In fact the function may not even be defined at "a", but the limit could still exist. So the fact that f(1)=3 is irrelevant to the problem. When looking for the limit, we must find a number that the function gets very close to as x approaches "a". It must get close to the same number when approaching from the left or right, or else the limit does not exist. In the case of this function, I think you might have made an error in typing it when you said that F(x) is equal to "X+" for x>1. But whatever it is, just see what number the function gets close to as x gets close to 1 from the right and the left. If they are the same number, then this is the limit; if not, then the limit does not exist.
sorry that should be x+1
ok so
lim(x->1+)=(1+1)=2
lim(x->1-)=(1+1)=2 so the limit exists, i don't understand how that helps in finding the overall limit of F(x) at 1.
So the limit is 2. The limit is just the number the function approaches from both the left and the right.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
