MHB Find Limit of Series w/o Quotations: 65 Characters
  • Thread starter Thread starter IHateFactorial
    Series Value
The series defined by the recurrence relation $$a_{n+1} = \frac{4}{7}a_n + \frac{3}{7}a_{n-1}$$ with initial conditions $$a_0 = 1$$ and $$a_1 = 2$$ converges to a limit as n approaches infinity. The limit can be found by analyzing the characteristic equation, leading to a closed form solution of $$a_n = \frac{17 - 7\left(-\frac{3}{7}\right)^n}{10}$$. As n increases, the term involving $$\left(-\frac{3}{7}\right)^n$$ approaches zero. Therefore, the limit is $$\lim_{n\to\infty} a_n = \frac{17}{10}$$. This confirms that the series converges to a finite value rather than diverging to infinity.
IHateFactorial
Let $${a}_{n+1} = \frac{4}{7}{a}_{n} + \frac{3}{7}{a}_{n-1}$$ where a0 = 1, and a1 = 2.
Find $$\lim_{{n}\to{\infty}}{a}_{n}$$
Well, seeing as it says that x approaches infinity, the difference between where points an-1, an, and an+1 are plotted on the y-axis is almost insignificant, so we can simply apply a common value of x to all ais in the function. It would become:
$$x = \frac{4}{7}x + \frac{3}{7}x = \frac{7}{7}x = x$$
Seeing as x equals itself, the higher the value of n, we can say that:
$$\lim_{{n}\to{\infty}}{a}_{n} = \infty$$
Is this right? Or did I screw it up?
Mathematics news on Phys.org
What I would do here is look at the characteristic equation for the linear homogeneous recursion:
$$7r^2-4r-3=0$$
$$(7r+3)(r-1)=0$$
And so we know the closed form is:
$$a_n=c_1\left(-\frac{3}{7}\right)^n+c_2$$
And we can use the initial values to determine the parameters:
$$a_0=c_1+c_2=1$$
$$a_1=-\frac{3}{7}c_1+c_2=2$$
Solving this system, we find:
$$c_a=-\frac{7}{10},\,c_2=\frac{17}{10}$$
Hence:
$$a_n=\frac{17-7\left(-\dfrac{3}{7}\right)^n}{10}$$
And so we find:
$$\lim_{n\to\infty}a_n=\frac{17}{10}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
