Find magnitude of the magnetic field
To determine the magnetic field's magnitude at a point on the y-axis due to a current-carrying wire, the formula dB = (μ/4π) ((Ids x r)/r^2) is used. A small element dx along the wire is considered, with its distance from the point on the y-axis calculated as sqrt(x^2 + y^2). The integration of the magnetic field contributions from the wire segment is necessary, leading to the expression B = μo/4π*I*∫[x*dx/(x^2 + y^2)^(3/2)]. The integration limits range from x = 0 to x = 3 cm, and the final equation for the magnetic field is derived as B = - μo/4π*I/sqrt(x^2 + y^2). Understanding the integration process is crucial for solving the problem accurately.
define_normal
A wire carries a current of 30A along the x-axis from x = 0 to x = 3.0 cm. Determine the magnitude in uT of the magnetic field at the point y = 4.0 cm on the y-axis.
dB = (u/4pi) ((Ids x r)/r^2)
We tried using this formula, but it didn't work. We are lost. Please help! Be descriptive if you can.
If you take a small element dx on x-axis at a distance x from the origin, its distance from a point on the y-axis is sqrt(x^2 + y^2)
Now (dx)xr = dx*sinθ, where r is the unit vector along r and θ is the angle between r and y-axis.
sinθ = x/sqrt(x^2 + y^2)
Substitute these values in dB and take the integration from x = 0 to x = 4
We don't understand how we're supposed to integrate. Isn't there an R^2 in the bottom?
Yes. It is there.
B = μο/4π*I*Intg[ sinθ*dx/( x^2 + y^2 )
If you substitute the value of sinθ,the expression becomes
B = μο/4π*I*Intg[ x*dx/( x^2 + y^2 )^3/2
Now find the integration and substitute the limits.
Can you write out what would be the exact (B=) equation?
B = - μo/4π*I/sqrt(x^2 + Y^2)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
