MHB Find Magnitude of Total Contact Force on 20kg Box in 3 Cases
The discussion focuses on calculating the total contact force on a 20 kg box in three scenarios involving horizontal pulling and pushing forces. For case (a), the calculated contact force is 204N, while the textbook states it should be 196N. In case (b), the user arrives at 213N, but the textbook claims the answer is 183N, indicating a misunderstanding of the vertical component of the applied force. For case (c), the user finds 187N, while the textbook suggests 209N, again highlighting discrepancies in interpreting the forces involved. The conversation emphasizes the importance of understanding normal force calculations and suggests using free body diagrams for clarity.
Shah 72
MHB
A box of mass 20 kg is at rest on a rough horizontal ground. Find the magnitude of the total contact force in each of the cases.
a) The box is pulled horizontally to the right by a force of 40N
b) the box is pushed to the left by a force of 50N at 15 degree above the horizontal .
c) the box is pushed to the left by a force of 50N at 15 degree below the horizontal.
Mathematics news on Phys.org
I have worked out the ans for a) will be 204N.
b) iam getting the ans 213N, but the textbook says 193N
c) I get the ans 187N , the textbook ans is 218N.
I don't get any of those values, yours or the text. I'm interpreting total contact force as the Normal Reaction Force the rough (assumedly horizontal) surface exerts upward on the box. Is that how your text defines it?
Is there more information that you haven't posted?
The question is Q(3)
This is the exact info in the textbook. And iam getting a different ans from the ans given in the textbook.
(a) normal contact force = weight = 20g = 196 N
(b) normal contact force = weight - vertical component of the applied force = 20g - 50sin(15) = 183 N
(c) normal contact force = weight + vertical component of the applied force = 20g + 50sin(15) = 209 N
may help your understanding if you sketched free body diagrams for each situation
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
