Find Max Velocity & Altitude of Rocket: Mass, Thrust, Burn Time
To find the maximum velocity and altitude of a rocket, the discussion emphasizes using the Rocket Equation, which accounts for changing mass as fuel is consumed. Key equations include those for motion (x = x0 + vt, v = v0 + at) and force (f = ma), with gravity affecting acceleration. The example provided illustrates specific values for mass, thrust, and burn duration, leading to calculated max velocity and altitude. Participants suggest that understanding the role of gravity and engine acceleration is crucial for solving the problem. Additional resources and clearer problem formatting are recommended for better comprehension.
strttnr
what equation would i use to find the max velocity and max alt of a rocket. the probem gave me mass of rocket (g), mass of engine (g), mass of propellant (g), average thrust of engine(Newtons), burn duration of the engine (seconds). i got an example which is massrocket=23,mass engin=16.2,massproppelant=3.12, averagethrust=8 and burndurationengine=.5
their max vel=101.37 and max alt = 549.621
it gave me some equations which are x=x0+vt , v=v0+at , x=x0+v0t+.5at"square" and f=ma
(x=distance,v=velocity, t=time, a= acceleration, f=force, m=mass and 9.8 as grav m/s"square
i need better understanding of what information goes where plug into equation
The simplest thing would be to go to wikipea.org and search on Rocket Equation. That will give you plenty of information to read. Seems like it should also be in your textbook, but maybe they want you to do some outside reading...
Welcome to the PF, BTW.
thanks ...but this is just a problem for computer progamming but i don't even got a txt book to rely on to get help and i tried wiki and the way they explain it is too technical and confusing.. is there anywhere else or possibly give a link or explain to me in simplest terms on how to go about this problem using the example provided
This is just a bit more works than a simple projectile motion. Just remember there are two things to consider
1. gravity (g or -g)
2. engine also causes a kind of acceleration
it is very difficult to read your post, words become "compounds"state the entire problem using the given posting format. this helps readability
and of course, search around google
The other part of the Rocket Equation takes into account that the rocket becomes lighter as it burns off fuel...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
