MHB Find maximum area of a triangle
anemone
MHB
POTW Director
Given two moving points $A(x_1,\,y_1)$ and $B(x_2,\,y_2)$ on parabola curve $y^2=6x$ with $x_1+x_2=4$ and $x_1\ne x_2$ and the perpendicular bisector of segment $AB$ intersects $x$-axis at point $C$. Find the maximum area of $\triangle ABC$.
Mathematics news on Phys.org
This seems to be one of those problems where the calculation is easier if you make it more general. I shall take the parabola to be $y^2 = 4ax$ (so eventually $a$ will become $\frac32$), and the condition on the points to be $x_1+x_2 = k$ (with $k=4$ eventually).
Let $A$ and $B$ be the points $(as^2, 2as)$, $(at^2,2at)$, so that $as^2 + at^2 = k$. The line $AB$ has slope $\dfrac2{s+t}$ and midpoint $\bigl(\frac12k,a(s+t)\bigr)$. Its perpendicular bisector therefore has equation $y - a(s+t) = -\tfrac12(s+t)(x - \tfrac12k)$, and it meets the $x$-axis at the point $(2a+\tfrac12k,0)$. The area $\Delta$ of triangle $ABC$ is the absolute value of $$\frac12\begin{vmatrix}as^2&2as&1\\ at^2&2at&1\\ 2a+\frac12k&0&1 \end{vmatrix} = (2a+\tfrac12k)a(s-t) + a^2st(s-t).$$ Now let $u = s-t$ and $v = s+t$. Then $u^2+v^2 = 2(s^2+t^2) = \frac{2k}a$ and $v^2-u^2 = 4st$, so that $st = \frac14(v^2-u^2) = \frac12\bigl(\frac ka - u^2\bigr)$. Therefore $$\Delta = \left| (2a+\tfrac12k)a(s-t) + a^2st(s-t) \right| = \left| (2a+\tfrac12k)au + a^2\tfrac12\bigl(\tfrac ka - u^2\bigr)u\right| = \left| (2a+k)au - \tfrac12a^2u^3 \right|.$$ Now plug in the values $a=\frac32$ and $k=4$ to get $\Delta = \left| \frac{21}2u - \frac98u^3\right|$. Also, $u^2 \leqslant u^2+v^2 = \frac{2k}a = \frac{16}3$, so that $u$ must lie in the interval $\left[-\frac4{\sqrt3},\frac4{\sqrt3}\right]$. The maximum value of $ \left| \frac{21}2u - \frac98u^3\right|$ in that interval occurs at the turning point when $\frac{21}2 - \frac{27}8u^2 = 0$ and so $u = \frac{2\sqrt7}3$. Therefore the maximum value of $\Delta$ is $\Delta_{\max} = \frac{2\sqrt7}3\left(\frac{21}2 - \frac98\frac{28}9\right) = \frac{14}3\sqrt7 \approx 12.347$.
Having found $u$, it is easy to work out corresponding values of $s$ and $t$, which can be taken as $\frac13(\sqrt7\pm\sqrt5)$. The points $A$, $B$ and $C$ are then $$A = \left( 2 - \tfrac13\sqrt{35}, \sqrt7 - \sqrt5\right) \approx (0.08,0.41),$$ $$B = \left( 2 + \tfrac13\sqrt{35}, \sqrt7 + \sqrt5\right) \approx (3.97,4.88),$$ $$C = (5,0).$$
[TIKZ]\draw [help lines, ->] (-1,0) -- (6.5,0) ;
\draw [help lines, ->] (0,-3) -- (0,6.5) ;
\draw [domain=-1:2, samples=100] plot ({1.5*\x*\x}, {3*\x });
\coordinate [label=left:$A$] (A) at (0.03,0.41) ;
\coordinate [label=above left:$B$] (B) at (3.97,4.88) ;
\coordinate [label=below:$C$] (C) at (5,0) ;
\draw [thick] (A) -- (B) -- (C) -- cycle ;
\draw (2,2.65) -- (C) ;
\foreach \x in {2,4,6} { \draw (\x,-0.1) node [ below ] {$\x$} -- (\x,0.1) ;
\draw (-0.1,\x) node [ left ] {$\x$} -- (0.1,\x) ; } ;[/TIKZ]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
