Chemistry Find out the amount of the elements
  • Thread starter Thread starter Say17
    Basic chemistry
To find the number of moles in 27g of water, the calculation involves determining the molar mass of H2O, which is 18.02 g/mol. Dividing 27g by 18.02 gives 1.5 moles of water. To find the grams of each element, calculate the mass of hydrogen and oxygen in water based on their proportions in the formula. For every mole of water, there are 2 grams of hydrogen and 16 grams of oxygen, so for 1.5 moles, multiply these amounts accordingly. Understanding the molar mass and the composition of water is essential for accurate calculations.
Say17
From the following list, indicate the condition(s) that will enable you to obtain at least 27 g of water.
H2O = 2*1.01 + 16 = 18.02
Hi everyone,
I just don't get it how to compute the following task. First I have to find out many moles are in 27g of Water.
27g/18.02 = 1.5mol but afterwards how do I find each elements gram?
d is the correct answer.
Many ways to skin that cat.
You can start with the reaction equation and treat a,b,c,d as input into a limited reagent problem.
You can calculate mass of hydrogen and oxygen present in water. That's what the formula tells you:
This is basically what you need - molar mass is sum of masses of all elements involved. How many grams of hydrogen per mole of water? What if you have 1.5 times the amount?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
